02-29-2016, 04:49
#5 (permalink)
Member: 1433088
Thanks Meter: 15 | No Service
NETWORK : UNBLOCK
IMEI Cert: FAIL, -9
LOG: Quote:
Вас приветствует Octoplus/Octopus Box Samsung software версии
2.2.1
To connect SM-G928F phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
To connect SM-G920T phone you have to perform the following steps:
Platform: Samsung Android
Selected port: COM1
Selected model: SM-G920T
ADB server killed.
Warning: Selected model (SM-G920T) differs from the detected one
(SM-G900P)!
If you want select (SM-G900P) as (SM-G920T) model, please check
"manual select".
Performed by 2.2.1 software version
To connect SM-G920P phone you have to perform the following steps:
Selected port: COM1
Selected model: SM-G920P
Reading info, please wait...
Warning: Selected model (SM-G920P) differs from the detected one
(SM-G900P)!
If you want select (SM-G900P) as (SM-G920P) model, please check
"manual select".
To connect SM-G900P phone you have to perform the following steps:
6. Go to dial window.
7. Enter "*#3424#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Restart phone.
11. Press "Read Info" in software.
Selected port: COM1
Selected model: SM-G900P
Detected phone model: SM-G900P
Firmware compiled date: Thu Jul 30 15:39:53 KST 2015
PDA version: G900PVPU3BOG1
CSC version: G900PSPT3BOG1
SW version: G900PVPU3BOG1
Phone SN: 00000000000
Android version: 5.0 (LRX21T)
Selected port: COM1
Reading info...
Mode: Normal
Firmware compiled date: Aug 05 2014
Firmware compiled time: G900P.00
Firmware released date: Jul 30 2015
Firmware released time: 14:48:13
SW Version: MPSS.DI.2.0.1.c2-00082-M8974AAAAANRZM-1
Checking Root:
Phone is not Rooted.
Selected port: COM1
Rebooting phone in Download Mode...
Phone successfully rebooted in Download Mode.
Selected port: COM1
ADB server killed.
Selected port: COM1
Reading info...
Mode: Normal
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung
\BACKUP\Security-SM-G900P-29-02-2016_13-36-31-.asec file
Wiping EFS...
EFS wipe successfully
Phone will restart now. Please don't disconnect cable!
Searching for a phone. Please wait...
Reading info...
Mode: Normal
Wipe security successfully complete.
Selected port: COM1
Selected file: F:\Samsung\G900P\Cert-SM-G900P-99000447615965.cert
ADB server killed.
Checking Root:
Phone is Rooted.
Checking Certificate file...
Certificate file successfully checked
Writing Certificate...
Writing new phone IMEI...
Checking certificate compatibility...
Certificate is compatible
Certificate has been written successfully
Please, restart the phone to apply changes
2.2.1
Selected port: COM1
ADB server killed.
(SM-G900P)!
"manual select".
Selected port: COM1
(SM-G900P)!
"manual select".
10. Restart phone.
Selected port: COM1
Selected port: COM1
Reading info...
Mode: Normal
Checking Root:
Selected port: COM1
Selected port: COM1
ADB server killed.
Selected port: COM1
Reading info...
Mode: Normal
Checking Root:
Phone is Rooted.
Wiping EFS...
Reading info...
Mode: Normal
Selected port: COM1
ADB server killed.
Checking Root:
Phone is Rooted.
Selected port: COM1
Mode: Emergency
Phone was not found on the selected port!
Searching for USB diagnostic port...
Connecting to phone on COM63
Phone connection failed
Connecting to phone on COM64
No diagnostic ports found!
Connecting to phone on COM45
Connecting to phone on COM3
Selected action can’t be performed
Selected port: COM1
Reading info...
Mode: Normal
Send SPC...
Writing QCN failed
Performed by 2.2.1 software version | NVM https://drive.google.com/open?id=0B_...WZWZjRmal9zQnc |
