08-15-2015, 10:36 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Romania Focsani
Member: 149135 Status: Offline Thanks Meter: 234 | G900T unlock problem [Solved] Welcome to Octoplus/Octopus Box Samsung software version 2.0.3 ----------------------------------------------------------------------------------- To connect SM-G900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900T Reading info... Mode: Normal Firmware compiled date: Apr 16 2015 Firmware compiled time: 19:00:00 Firmware released date: Jun 10 2015 Firmware released time: 18:14:37 SW Version: MPSS.DI.2.0.1.c2-00158-M8974AAAAANRZM-1 Detected phone model: SM-G900T Firmware compiled date: Thu Jun 11 02:15:27 KST 2015 PDA version: G900TUVU1FOF6 CSC version: G900TTMB1FOF6 SW version: G900TUVU1FOF6 Phone IMEI: Unknown Phone SN: R38FA0PYREF Android version: 5.1.1 (LMY47X) Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Last edited by Octopus box; 08-17-2015 at 17:42. |
08-15-2015, 12:09 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please try to perform "Unlock" operation as for SM-E700H (with enabled "Manual select" option). Post here result and full Software log of the operation. |
08-17-2015, 07:28 | #3 (permalink) |
Member: 149135 Status: Offline Thanks Meter: 234 | Not work.. Welcome to Octoplus/Octopus Box Samsung software version 2.0.3 ----------------------------------------------------------------------------------- To connect SM-G900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-E700H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-E700H Reading info, please wait... Warning: Selected model (SM-E700H) differs from the detected one (SM-G900T)! If you want select (SM-G900T) as (SM-E700H) model, please check "manual select". ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-E700H Reading info, please wait... Detected phone model: SM-G900T Firmware compiled date: Thu Jun 11 02:15:27 KST 2015 PDA version: G900TUVU1FOF6 CSC version: G900TTMB1FOF6 SW version: G900TUVU1FOF6 Phone IMEI: Unknown Phone SN: R38FA0PYREF Android version: 5.1.1 (LMY47X) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-E700H Detected phone model: SM-G900T Firmware compiled date: Thu Jun 11 02:15:27 KST 2015 PDA version: G900TUVU1FOF6 CSC version: G900TTMB1FOF6 SW version: G900TUVU1FOF6 Phone IMEI: Unknown Phone SN: R38FA0PYREF Android version: 5.1.1 (LMY47X) Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-E700H Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-E700H Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-E700H Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-E700H Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-E700H Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-E700H Detected phone model: SM-G900T Firmware compiled date: Thu Jun 11 02:15:27 KST 2015 PDA version: G900TUVU1FOF6 CSC version: G900TTMB1FOF6 SW version: G900TUVU1FOF6 Phone IMEI: Unknown Phone SN: R38FA0PYREF Android version: 5.1.1 (LMY47X) Phone unlocking failed |
The Following User Says Thank You to djdansmart For This Useful Post: |
08-17-2015, 07:57 | #4 (permalink) |
Freak Poster Join Date: May 2011 Location: INDIA
Member: 1584831 Status: Offline Thanks Meter: 46 | in ur log ,unable 2 to read imei. first chek ur imei in ur ph. if ok ,then connect d ph in setup n get info. if still imei doesn't shows,its setup problem . n 2n option is ,u have repair imei n write qcn ur ph will be ok. |
08-17-2015, 15:14 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | It is highly not recommended to downgrade phone's firmware from Android 5.1.1, it may damage your device. You can try to do it only on your own risk. We research this problem and will notify You about possible solution. Last edited by Octopus box; 08-17-2015 at 17:41. |
08-17-2015, 16:08 | #8 (permalink) |
Member: 149135 Status: Offline Thanks Meter: 234 | Downgrade from 5.1.1 to 5.0..wipe data,vipe cache,reboot. Phone ok..no imei damaged,all ok! After that error in red line..phone unlocked..signal ok..make call..all OK! Platform: Samsung Android Selected port: COM112 Selected model: SM-G900T Detected phone model: SM-G900T Firmware compiled date: Sat Feb 7 14:18:29 KST 2015 PDA version: G900TUVU1DOB1 CSC version: G900TTMB1DOB1 SW version: G900TUVU1DOB1 Phone IMEI: Unknown Phone SN: R38FA0PYREF Android version: 5.0 (LRX21T) ERROR : 8/17/2015 4:11:04 PM > Reading security failed. INFO : 8/17/2015 4:12:39 PM > ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM112 Selected model: SM-G900T Reading info... Mode: Normal Firmware compiled date: Dec 01 2014 Firmware compiled time: 23:00:00 Firmware released date: Feb 7 2015 Firmware released time: 11:23:36 SW Version: MPSS.DI.2.0.1.c2-00114-M8974AAAAANRZM-1 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked WARN To finish the operation, please restart the phone via phone's menu. |
