10-29-2014, 22:45 | #1 (permalink) |
Crazy Poster Join Date: Jun 2014
Member: 2213224 Status: Offline Thanks Meter: 20 | G900T Writing Cert [Solved] Selected port: COM475 Selected model: SM-G900T Selected file: D:\Samsung Backup\SM-G900H_xxxxxxxxxxx . cert Proper android device not found. Make shure that "USB debug" option on the device is turned on. Writing Certificate failed SM-G900T/4.4.2/Rooted/Octaplus 1.7.3 Question 1) I read G900H cert can be written on G900T. May be someone can verify if this is true. 2) Getting "Writing Cert. Failed" - Any solution? Thanks in advance Last edited by Octopus box; 11-26-2014 at 15:17. |
10-30-2014, 05:12 | #2 (permalink) |
Major Poster Join Date: Aug 2009
Member: 1097298 Status: Offline Thanks Meter: 5 | Hello. I was getting the same problem. what I did was to clean cache and factory reset. I was able to change the IMEI but now I get " not registered on netowkor" what should I do next |
10-30-2014, 08:09 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Hello. Quote:
10-30-2014, 18:29 | #5 (permalink) |
Member: 2213224 Status: Offline Thanks Meter: 20 | Platform: Samsung Android Selected port: COM169 Selected model: SM-G900T Selected file: D:\Samsung Backup\Cert-SM-G900F_352558067456401_00000000000.cert Detected phone model: SM-G900T Firmware compiled date: Wed Mar 26 13:28:24 KST 2014 PDA version: G900TUVU1ANCH CSC version: G900TTMB1ANCH SW version: G900TUVU1ANCH Phone IMEI: 352959060487205 Phone SN: RV8F41JJYJF Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Writing Certificate failed now i'm stuck here Steps: Wipe cache/wipe data/installed supersu/disabled KNOX/Wipe Security/Write G900F Cert |
10-30-2014, 18:34 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Please do the next: 1. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 2. Take out SIM and SD cards from the phone. 3. Make Factory data reset and wipe cache partition. 4. Re-flash the phone. 5. Make Wipe Security again. 6. Write Certificate again. 7. Close the Software. 8. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the link, we will check, where can be the problem with the device. |
10-30-2014, 22:06 | #8 (permalink) |
No Life Poster Join Date: Mar 2005
Member: 127049 Status: Offline Thanks Meter: 49 | Just done IMEI REPAIR Samsung T-Mobile SM-G900T all working okie, but not working on T-Mobile network because all Certificate in support site are IMEI LOCKED all AT&T network are okie, Full signal Welcome to Octoplus/Octopus Box Samsung software version 1.7.3 ----------------------------------------------------------------------------------- To connect SGH-A927 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Type *#782872#. 3. Press confirm button. 4. Type *#7465625# and leave appeared message on phone screen. 5. Connect USB cable and select Diagnostics COM port. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM51 Selected model: SM-G900T Connect phone to UART cable, phone must be ON and screen must be permanently active! Searching for a phone. Please wait... Found phone on COM51 Reading info... Phone model: SM-G900T Phone IMEI: 3518810xxxxx8 MSL address: RV8F40RRF2 Requesting MSL code... Connecting to server Username: Login error: Incorrect Username! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM51 Selected model: SM-G900T Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM51 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM51 Selected model: SM-G900T Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM51 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM51 Selected model: SM-G900T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM43 Mode: Normal Phone model: SM-G900T Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: May 23 2014 Firmware released time: 19:41:46 Phone IMEI: 351881-06-xxxxx-8 SW version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM43 Selected model: SM-G900T ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: G900TTMB1ANE6 SW version: G900TUVU1ANE6 Phone IMEI: 351881061xxxxxxx88 Phone SN: RV8F40RRF2J Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: May 23 2014 Firmware released time: 19:41:46 SW Version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-G900T-351881061xxxxx88-30-10-2014_13-08- 44-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G900T-35188106xxxxxxx88-30-10-2014_13-12- 25-.asec file Wiping EFS... EFS wipe successfully Phone will restart now Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: May 23 2014 Firmware released time: 19:41:46 SW Version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM43 Selected model: SM-G900T Selected file: C:\Users\Dienson X Nguyen\Desktop\Cert-SM-G900T_ 35255806xxxxxx1.cert Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: G900TTMB1ANE6 SW version: G900TUVU1ANE6 Phone IMEI: Unknown Phone SN: RV8F40RRF2J Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Checking Certificate failed Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM43 Selected model: SM-G900T Reading info, please wait... Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: Unknown SW version: G900TUVU1ANE6 Phone IMEI: Unknown Phone SN: RV8F40RRF2J Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM43 Selected model: SM-G900T Selected file: C:\Users\Dienson X Nguyen\Desktop\Cert-SM-G900T_ 352558xxxxxxxxx1.cert Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: G900TTMB1ANE6 SW version: G900TUVU1ANE6 Phone IMEI: Unknown Phone SN: RV8F40RRF2J Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Checking Certificate failed Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM43 Selected model: SM-G900T Reading info, please wait... Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: G900TTMB1ANE6 SW version: G900TUVU1ANE6 Phone IMEI: Unknown Phone SN: RV8F40RRF2J Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM43 Selected model: SM-G900T Selected file: C:\Users\Dienson X Nguyen\Desktop\Cert-SM-G900T_ 352558067456419_00000000000.cert Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: G900TTMB1ANE6 SW version: G900TUVU1ANE6 Phone IMEI: Unknown Phone SN: RV8F40RRF2J Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now Certificate has been written successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM43 Selected model: SM-G900T Reading info, please wait... Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: G900TTMB1ANE6 SW version: G900TUVU1ANE6 Phone IMEI: 352558067456419 Phone SN: RV8F40RRF2J Android version: 4.4.2 (KOT49H) Thank A lot And I have question This phone done good on Window7 64bit, but on window XP 32bit it stop at WIPING EFS when it goes to "Wiping EFS" it take like 3 mins then "Samsung tool version 1.7.3" shut off, like close itself Do U know any problem on it I love Octoplus box |
10-31-2014, 07:47 | #9 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Quote:
11-07-2014, 21:07 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | @ JowiiStylePR Please do the next: 1. Perform "Wipe Security" operation. 2. Make Factory Reset and Wipe Cache Partition from Recovery Mode. 3. Perform "Write Cert" operation. Send us full Software logs of all performed operations in PM. Last edited by Octopus box; 11-08-2014 at 08:52. |
11-08-2014, 08:53 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | To get signal, try to write this QCN: https://mega.co.nz/#!Wg4QDRbB!Qmhzwa...AxyNgjG5fofST0. |
11-09-2014, 10:05 | #15 (permalink) | |
You should re-flash the device with different firmwares and check, whether modem is correct (baseband is not Unknown). And only then (when phone's modem part will be correct), root the phone, perform "Wipe Security" and "Write Cert" to Repair IMEI. It is not possible to repair IMEI, if phone's modem part is damaged. | |
