06-05-2016, 12:09 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: chandigarh Age: 42
Member: 349524 Status: Offline Sonork: 100.1622727 Thanks Meter: 122 | g900w8 unlock issue Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 ----------------------------------------------------------------------------------- To connect GT-N7100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N900W8 Reading info... Mode: Normal Firmware compiled date: Jan 28 2016 Firmware compiled time: 23:00:00 Firmware released date: Apr 9 2016 Firmware released time: 15:32:17 SW Version: MPSS.DI.2.0.1.c2-00201-M8974AAAAANRZM-1 Please, press "OK" button on the phone to allow USB debugging.. Warning: Selected model (SM-N900W8) differs from the detected one (SM-G900W8)! If you want select (SM-G900W8) as (SM-N900W8) model, please check "manual select". Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.5 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N900W8 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM184 Mode: Normal Phone model: SM-N900W8 Firmware compiled date: Jan 28 2016 Firmware compiled time: 23:00:00 Firmware released date: Apr 9 2016 Firmware released time: 15:32:17 Phone IMEI: 353021-07-043482-3 SW version: MPSS.DI.2.0.1.c2-00201-M8974AAAAANRZM-1 Performed by 2.2.5 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM184 Selected model: SM-N900W8 Reading info... Mode: Normal Firmware compiled date: Jan 28 2016 Firmware compiled time: 23:00:00 Firmware released date: Apr 9 2016 Firmware released time: 15:32:17 SW Version: MPSS.DI.2.0.1.c2-00201-M8974AAAAANRZM-1 Warning: Selected model (SM-N900W8) differs from the detected one (SM-G900W8)! If you want select (SM-G900W8) as (SM-N900W8) model, please check "manual select". Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.5 software version ----------------------------------------------------------------------------------- To connect SM-G900W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM184 Selected model: SM-G900W8 Reading info... Mode: Normal Firmware compiled date: Jan 28 2016 Firmware compiled time: 23:00:00 Firmware released date: Apr 9 2016 Firmware released time: 15:32:17 SW Version: MPSS.DI.2.0.1.c2-00201-M8974AAAAANRZM-1 Detected phone model: SM-G900W8 Firmware compiled date: Sat Apr 9 16:21:16 KST 2016 PDA version: G900W8VLU1DPD3 CSC version: G900W8OYA1DPD3 SW version: G900W8VLU1DPD3 Phone SN: RV8G70CS89R Android version: 6.0.1 (MMB29M) Country: Canada HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Codename: kltevl Checking Root: Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.5 software version |
06-06-2016, 10:42 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please install the latest Software version and repeat "Unlock"/"Fast Unlock" operation. If request for an unlock code will remain - try to enter 00000000, 11111111 and 12345678 codes. |
06-09-2016, 17:20 | #3 (permalink) | |
Freak Poster Join Date: May 2014
Member: 2194348 Status: Offline Thanks Meter: 52 | Quote:
06-09-2016, 20:28 | #5 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Edmonton AB
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | i think you software version is 6.0.1 if so downgrade to 5.1.1 its safe i have done it many times, after downgrade you must factory rest, which will delete all data |
