Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 02-08-2019, 16:31   #1 (permalink)
DundyTM's Avatar
Member: 889564
Thanks Meter: 321
>>> G903F stuck on logo/bootlop after FRP [Solved]
Hi, mates.
I had to remove FRP of one S5 NEO - G903F. After removing FRP, the phone went on bootloop. Restart over and over again at Samsung logo.
The firmware version of the phone was G903FXXU2BRH2. So I flashed the set with it's original version (by the way, with the one from the support area I had hidden.img error, so I had to find another XXU2BRH2), but the set still reboot at logo. I did factory/wipe cache after flashing, everything, but again - bootloop. Im stuck, mates. Im flashing with latest bootloaders and the phone again stucks at logo! What else can I do to revive the set? Any ideas, mates? Here's the log.
Welcome to Octoplus Box Samsung software version 2.7.7
To connect SM-G903F phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3. Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
Platform: Samsung Android
Selected port: COM1
Selected model: SM-G903F
Operation: Reset FRP - UserData
Reset FRP/ Reactivation lock operation for SM-G903F will delete all user data on the phone (contacts, pictures and others)!
NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service.
Connecting to server...
Connecting to server...Ok!
Checking resource files...
Resource files already downloaded.
Please put the phone into Download Mode and connect USB cable.
To put SM-G903F into Download Mode, You have to perform the following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" + "Home" + "Power ON" keys.
3. When phone turns on, press "Volume+" key.
Waiting for phone...
Firmware write started.
Writing Custom section...
Custom section has been written successfully.
FRP lock is successfully reseted!
Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset"
Performed by 2.7.7.4 Software version.
Selected AP file: E:\GSM\Samsung\G\G903F\VD2-G903FXXU2BRH2-20181012094150\G903FXXU2BRH2_G903FVFG2BRH2_G903FXXU2BRH2_HOME.tar.md5
Found phone on
Advanced mode!
Writing BOOTLOADER section...
BOOTLOADER section has been written successfully.
Writing CM section...
CM section has been written successfully.
Writing BOOT section...
BOOT section has been written successfully.
Writing RECOVERY section...
RECOVERY section has been written successfully.
Writing SYSTEM section...
SYSTEM section has been written successfully.
Writing CACHE section...
CACHE section has been written successfully.
Writing HIDDEN section...
Writing Firmware Failed
Selected AP file: E:\GSM\Samsung\G\G903F\G903FXXU2BRH2_G903FOXX2BRH2_G903FXXU2BRH2_HOME.tar.md5
Found phone on
Advanced mode!
HIDDEN section has been written successfully.
Writing RADIO section...
RADIO section has been written successfully.
Firmware writing successfully completed.
Old 02-11-2019, 10:55   #2 (permalink)
DundyTM's Avatar
Member: 889564
Thanks Meter: 321
By the way, is there a BIN 2 Combination on the way? Im willing to try everything...
Old 02-11-2019, 12:16   #3 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 22,980
We will try to find combination firmware for this device, we will inform You.
Old 02-11-2019, 12:16   #4 (permalink)
Member: 2504544
Sonork: www.sonork.com
Thank you more dear participation
Old 02-11-2019, 12:20   #5 (permalink)
Member: 1146942
Sonork: 100.1587278
If You are able to put the device into Download Mode, You can try to reflash your device with 4 file firmware, we will upload it to Support Area in one hour.
Old 02-11-2019, 13:30   #6 (permalink)
DundyTM's Avatar
Member: 889564
Thanks Meter: 321
Ok, mates. Waiting. Thank you for the support. I hope it works, cause Im really stuck.
Old 02-11-2019, 14:20   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
The 4 file firmware was added into Support Area.
Old 02-11-2019, 15:00   #8 (permalink)
DundyTM's Avatar
Member: 889564
Thanks Meter: 321
It's alive, mates! With the new 4 files firmware! Again - thank you for fast and adequate support! If you can explain what was the problem with the other firmwares and why with this exact firmware works - I'll be very gratefull.
Page generated in 0.23374 seconds with 7 queries
