07-17-2017, 12:46 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. Unfortunately downgrading is not always possible. On your own risk You can try to downgrade only phone's modem. Currently no solution to write a Cert file for Galaxy S6 phones on Android 7 firmwares. |
07-17-2017, 13:29 | #3 (permalink) |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Hi, depends on the version of Android 7 you have as the original stock firmware of the phone, you have to downgrade to version 6.0.1 to the recent security patch version seeing if the binary revision is compatible because otherwise you can not do the downgrade the phone hangs, to do this you have to download the firmware of the same country from Sammobile then use Odin unpacking the firmware in 4 files and upload them to Odin and make the flash note that if The firmware is not compatible with the binary Revisio because of the blocked bootloder you remain locked the phone, finished the whole test to write the certificate or use the patch doing repair IMEI and repair network |
07-18-2017, 02:15 | #4 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Pakistan/UAE/WorldWide Age: 26
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | Please tell me the correct 7.0 firmware installed in the phone right now I will help you to downgrade it to 6.0.1 Sent from my iPhone using Tapatalk |
07-25-2017, 15:15 | #5 (permalink) | |
Freak Poster Join Date: Dec 2006 Location: POMPEI
Member: 405174 Status: Offline Thanks Meter: 18 | Quote:
the firmware installed now is: nrd90m.g920fxxs5eqe6 baseband g920fxxu5eqcd Last edited by Octopus box; 07-25-2017 at 15:28. | |
07-25-2017, 16:13 | #6 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Hi, try to make the Dowgrade to this version of Android 6.0.1 just downloaded the firmware from Sammobile unzip the file in 4 files and make the firmware flash Security Patch Level 2017-03-01 Product code ITV PDA G920FXXS5DQC1 CSC G920FITV5DQA2 |
The Following User Says Thank You to amleto90 For This Useful Post: |
07-26-2017, 11:02 | #7 (permalink) | |
07-26-2017, 11:50 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | You can extract files from an original firmware in 2 steps: 1. Remove *.md5 extension. 2. Unzip *.tar archive. |
07-26-2017, 12:09 | #10 (permalink) | |
boot.img cache.img cm.bin hidden.img modem.bin recovery.img sboot.bin system.img How i do proceed? | |
07-26-2017, 12:25 | #11 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Hello use this program to unpack the firmware in 4 files below to find the link where to download it and how to do it http://forum.gsmhosting.com/vbb/f777...ndows-1874242/ |
08-07-2017, 22:48 | #12 (permalink) | |
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | Quote:
Sorry for the late I think your problem was solved if not so flash your phone with this combination file after that write cert https://androidfilehost.com/?fid=817550096634786996 Br Shahzaib jahangir #Unlockerplus | |
