04-12-2017, 15:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | g920f imei null ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Reading info, please wait... Detected phone model: SM-G920F Firmware compiled date: Tue Jul 5 17:07:18 KST 2016 PDA version: G920FXXS4DPG4 CSC version: G920FOJV3DPC1 SW version: unknown Android version: 6.0.1 (MMB29K) Sales code: THR Country: IRAN HW platform: exynos5 HW Chip: exynos7420 HW Modem: unknown Security patch level: 2016-07-01 Codename: zerofltexx Performed by 2.5.0 Software version. Selected firmware file: AP_G920FXXU3DPC2_CL7169835_QB8835185 _REV02_user_low_ship.oct Please put the phone into Download Mode and connect USB cable. To put SM-G920F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing PIT section... Writing Firmware Failed Performed by 2.5.0 Software version. Selected firmware file: AP_G920FXXU3DPC2_CL7169835_QB8835185 _REV02_user_low_ship.oct Selected PIT file: C:\Users\hamid\Desktop\666 \ZEROFLTE_EUR_OPEN_HIDDEN150M.pit Selected BOOT file: C:\Users\hamid\Desktop\666\BL_G920FXXU3DPC2 _CL7169835_QB8835185_REV02_user_low_ship.tar.md5 Selected AP file: C:\Users\hamid\Desktop\666\AP_G920FXXU3DPC2 _CL7169835_QB8835185_REV02_user_low_ship.tar.md5 Selected CP file: C:\Users\hamid\Desktop\666 \MODEM_G920FXXU3DPBT_CL2063796_QB_4493935_SIGNED.t ar.md5 Selected CSC file: C:\Users\hamid\Desktop\666 \CSC_OJV_G920FOJV3DPC1_CL7347408_QB8835455_REV02 _user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G920F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing PIT section... Writing Firmware Failed Performed by 2.5.0 Software version. |
04-12-2017, 16:04 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please fully charge phone battery, then try to write firmware again. Try to use different USB ports of PC motherboard for connection. Don't use any USB hubs, this is important. Last edited by Octopus box; 04-12-2017 at 16:24. |
04-13-2017, 08:37 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please re-install Samsung USB drivers, then try to write "G920FXXU5DPL4_G920FTMZ5DPL1_TMZ_Android_6.0.1 " firmware from the Support Area. Post here the result. |
04-13-2017, 09:14 | #9 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | Welcome to Octoplus/Octopus Box Samsung software version 2.5.0 ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-N915W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. drk repair error? |
04-13-2017, 09:29 | #10 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | Welcome to Octoplus/Octopus Box Samsung software version 2.5.0 ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. |
04-13-2017, 09:54 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Firmware file is available in the Support Area. To access Support Area, press "Go to support" button on "Support & options" tab of the Software. Also You can use Files Downloader on "Support & options" tab of the Software to browse, search and download files from the Support Area. "DRK fix" operation requires phone to have enabled USB debugging and to be connected in Normal Mode directly to PC, via USB cable. |
04-13-2017, 10:59 | #14 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | Welcome to Octoplus/Octopus Box Samsung software version 2.5.0 ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM23 Selected model: SM-G920F To put SM-G920F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G920F Operation was canceled Writing EFS was canceled. Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G920F Operation was canceled Writing security was canceled. Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM23 Selected model: SM-G920F To put SM-G920F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Repair EFS was canceled Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: G920FXXU5DPL6 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-10-01 Codename: zerofltexx Checking Root: Phone is Rooted. Initializing exploit... Executing exploit... DM-Verity verification..not good! Fixing DRK.. DRK fixed successfully Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Selected file: C:\Users\hamid\Desktop\cert-sm-g920f_ 359845064205185_rf8g410tn3e.cert Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: G920FXXU5DPL6 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-10-01 Codename: zerofltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920F-Unknown13-04-2017_02-12-28-.asec file Checking Certificate file... Certificate file successfully checked Initializing exploit...OK Executing exploit...OK Exploit has been executed successfully Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: G920FXXU5DPL6 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-10-01 Codename: zerofltexx Checking Root: Phone is Rooted. Initializing exploit... Executing exploit... Repairing network... Network is successfully repaired. Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: G920FXXU5DPL6 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-10-01 Codename: zerofltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920F-Unknown13-04-2017_02-18-51-.asec file Wiping EFS... Phone will restart now. Please don't disconnect cable! EFS wipe successfully Searching for a phone. Please wait... Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: unknown Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: unknown Security patch level: 2016-10-01 Codename: zerofltexx Repairing security Security repair successfully Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: unknown Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: unknown Security patch level: 2016-10-01 Codename: zerofltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920F-Unknown13-04-2017_02-21-58-.asec file Initializing exploit...OK Executing exploit...OK Exploit has been executed successfully New IMEI: 359937068039502 Writing new phone IMEI... Please make "Repair Network" operation after reboot! IMEI successfully repaired. Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Reading info, please wait... Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: G920FXXU5DPL6 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-10-01 Codename: zerofltexx Performed by 2.5.0 Software version. |
04-13-2017, 11:05 | #15 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | Welcome to Octoplus/Octopus Box Samsung software version 2.5.0 ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM23 Selected model: SM-G920F To put SM-G920F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G920F Operation was canceled Writing EFS was canceled. Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G920F Proper android device not found. Make shure that "USB debug" option on the device is turned on. DRK fixing failed! Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G920F Operation was canceled Writing security was canceled. Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM23 Selected model: SM-G920F To put SM-G920F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Repair EFS was canceled Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: G920FXXU5DPL6 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-10-01 Codename: zerofltexx Checking Root: Phone is Rooted. Initializing exploit... Executing exploit... DM-Verity verification..not good! Fixing DRK.. DRK fixed successfully Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Selected file: C:\Users\hamid\Desktop\cert-sm-g920f_ 359845064205185_rf8g410tn3e.cert Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: G920FXXU5DPL6 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-10-01 Codename: zerofltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920F-Unknown13-04-2017_02-12-28-.asec file Checking Certificate file... Certificate file successfully checked Initializing exploit...OK Executing exploit...OK Exploit has been executed successfully Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: G920FXXU5DPL6 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-10-01 Codename: zerofltexx Checking Root: Phone is Rooted. Initializing exploit... Executing exploit... Repairing network... Network is successfully repaired. Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: G920FXXU5DPL6 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-10-01 Codename: zerofltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920F-Unknown13-04-2017_02-18-51-.asec file Wiping EFS... Phone will restart now. Please don't disconnect cable! EFS wipe successfully Searching for a phone. Please wait... Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: unknown Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: unknown Security patch level: 2016-10-01 Codename: zerofltexx Repairing security Security repair successfully Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: unknown Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: unknown Security patch level: 2016-10-01 Codename: zerofltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920F-Unknown13-04-2017_02-21-58-.asec file Initializing exploit...OK Executing exploit...OK Exploit has been executed successfully New IMEI: 359937068039502 Writing new phone IMEI... Please make "Repair Network" operation after reboot! IMEI successfully repaired. Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Reading info, please wait... Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: G920FXXU5DPL6 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-10-01 Codename: zerofltexx Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: G920FXXU5DPL6 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-10-01 Codename: zerofltexx Checking Root: Phone is not Rooted. Repairing network failed. Performed by 2.5.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-G920F Detected phone model: SM-G920F Firmware compiled date: Sat Dec 10 17:17:11 KST 2016 PDA version: G920FXXU5DPLH CSC version: G920FOLB4DPJI SW version: G920FXXU5DPL6 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XXV Country: VIETNAM HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-10-01 Codename: zerofltexx Checking Root: Repairing network failed. Performed by 2.5.0 Software version. |
