01-29-2016, 19:56 | #1 (permalink) |
Freak Poster Join Date: May 2005 Location: Serbia Age: 45
Member: 146744 Status: Offline Thanks Meter: 25 | g920f reset screen lock problem [Solved] any suggestion? here is log: NFO : 1/29/2016 6:28:12 PM > Platform: Samsung Android INFO : 1/29/2016 6:28:12 PM > Selected port: COM105 INFO : 1/29/2016 6:28:12 PM > Selected model: SM-G920F WARN : 1/29/2016 6:28:14 PM > Connecting to server... INFO : 1/29/2016 6:28:15 PM > Connecting to server...Ok! INFO : 1/29/2016 6:28:15 PM > Checking resource files... INFO : 1/29/2016 6:28:15 PM > Resource files already downloaded. WARN : 1/29/2016 6:28:15 PM > Please put the phone into Download Mode and connect USB cable. WARN : 1/29/2016 6:28:27 PM > To put SM-G920F into Download Mode, You have to perform the following steps: WARN : 1/29/2016 6:28:27 PM > 1. Reconnect the battery. WARN : 1/29/2016 6:28:27 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 1/29/2016 6:28:27 PM > 3. When phone turns on, press "Volume+" key. INFO : 1/29/2016 6:28:27 PM > Waiting for phone... INFO : 1/29/2016 6:28:27 PM > Firmware write started. INFO : 1/29/2016 6:28:28 PM > Writing Recovery section... INFO : 1/29/2016 6:28:32 PM > Recovery section has been written successfully. WARN : 1/29/2016 6:28:32 PM > Please, put the phone into Recovery Mode and connect USB cable. WARN : 1/29/2016 6:30:34 PM > To put SM-G920F into Recovery Mode, please, perform the following steps: WARN : 1/29/2016 6:30:34 PM > 1. Reconnect the battery. WARN : 1/29/2016 6:30:34 PM > 2. Press and hold "Volume+" + "Home" + "Power ON" keys. WARN : 1/29/2016 6:30:34 PM > 3. Release the "Power ON" key when the Samsung logo appears. INFO : 1/29/2016 6:30:35 PM > Searching for a phone. Please wait... INFO : 1/29/2016 6:50:14 PM > Preparing phone.. INFO : 1/29/2016 6:50:17 PM > Resetting Screen Lock... WARN : 1/29/2016 6:50:21 PM > Reset Screen Lock successfully completed. INFO : 1/29/2016 6:50:21 PM > To unlock screen please input any password or pattern! Last edited by Octopus box; 02-06-2016 at 11:35. |
01-30-2016, 11:26 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Try to make Factory Reset and Wipe cache partition from Recovery Mode, then repeat "Reset Screen Lock" operation. Post here the result. |
01-30-2016, 11:39 | #3 (permalink) |
Member: 146744 Status: Offline Thanks Meter: 25 | Point of this bypass is not to lose data. I need data from this phone. I could do wipe and factory reset than reset screen lock option would be pointless. |
01-30-2016, 12:15 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please upload *.log and *.logx files of "Reset Screen Lock" operations to any file-sharing service and post here download link. We will check what might cause the problem *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
02-05-2016, 20:27 | #5 (permalink) |
Member: 146744 Status: Offline Thanks Meter: 25 | Thanks to Octopus support i managed to bypass fingerprint and alternative password on g920f. It's all ok now...I saved all data thanks to octopus support. Here is log : INFO : 2/3/2016 8:03:07 PM > Welcome to Octoplus/Octopus Box Samsung software version 2.1.9 INFO : 2/3/2016 8:03:13 PM > ----------------------------------------------------------------------------------- INFO : 2/3/2016 8:03:13 PM > To connect SM-G920F phone you have to perform the following steps: INFO : 2/3/2016 8:03:13 PM > 1. Disconnect USB cable from phone. INFO : 2/3/2016 8:03:13 PM > 2. Go to Menu->Settings->More->About Device. INFO : 2/3/2016 8:03:13 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 2/3/2016 8:03:13 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 2/3/2016 8:03:13 PM > 5. Turn on "USB Debugging" option. INFO : 2/3/2016 8:22:46 PM > ----------------------------------------------------------------------------------- INFO : 2/3/2016 8:22:46 PM > Platform: Samsung Android INFO : 2/3/2016 8:22:46 PM > Selected port: COM1 INFO : 2/3/2016 8:22:46 PM > Selected model: SM-G920F WARN : 2/3/2016 8:22:48 PM > Please, put the phone into Recovery Mode and connect USB cable. WARN : 2/3/2016 8:22:49 PM > To put SM-G920F into Recovery Mode, please, perform the following steps: WARN : 2/3/2016 8:22:49 PM > 1. Reconnect the battery. WARN : 2/3/2016 8:22:49 PM > 2. Press and hold "Volume+" + "Home" + "Power ON" keys. WARN : 2/3/2016 8:22:49 PM > 3. Release the "Power ON" key when the Samsung logo appears. INFO : 2/3/2016 8:22:49 PM > Searching for a phone. Please wait... INFO : 2/3/2016 8:22:49 PM > Preparing phone.. INFO : 2/3/2016 8:22:51 PM > Resetting Screen Lock... WARN : 2/3/2016 8:22:58 PM > Reset Screen Lock successfully completed. INFO : 2/3/2016 8:22:58 PM > To unlock screen please input any password or pattern! Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\03-02-2016_20-02-57.log" closed (2/3/2016 8:50:41 PM). |
The Following User Says Thank You to Marinsabac For This Useful Post: |
