08-15-2016, 16:01 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Try make Factory Reset and Wipe cache partition from Recovery Mode (if phone enters it). Try to reflash the phone. To remove Samsung Account, perform "Reset FRP/Reactivation/EE" operation. |
08-15-2016, 16:21 | #3 (permalink) |
No Life Poster Join Date: Feb 2013
Member: 1886712 Status: Offline Thanks Meter: 53 | Welcome to Octoplus/Octopus Box Samsung software version 2.3.3 ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G920F To put SM-G920F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock.. Operation was failed! Performed by 2.3.3 software version |
08-15-2016, 16:38 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Problem with reset of Reactivation lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. You can try to write "SBOOT_G920F_OJ1" Sboot file from the Support Arae, then repeat "Reset FRP/Reactivation/EE" operation. |
08-15-2016, 16:47 | #5 (permalink) |
Member: 1886712 Status: Offline Thanks Meter: 53 | Welcome to Octoplus/Octopus Box Samsung software version 2.3.3 ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: SBOOT_G920F_OJ1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G920F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed Performed by 2.3.3 software version |
08-15-2016, 17:20 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | If it is not possible to write SBoot of an older firmware - unfortunately currently no solution for such phones. |
