06-10-2015, 05:26 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | g920f trying writ cert file always fail i m trying with 2 phone bot always saying this Code: Welcome to Octoplus/Octopus Box Samsung software version 1.9.7 ----------------------------------------------------------------------------------- To connect SM-G900F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G920F Selected file: C:\Users\salim\Desktop\cert\g920f and g920t\cert-sm- g920f_359845064205185_rf8g410tn3e.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G920F Selected file: C:\Users\salim\Desktop\cert\g920f and g920t\cert-sm- g920f_359937060904505_r58g408w6fl.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G920F Selected file: C:\Users\salim\Desktop\cert\g920f and g920t\cert-sm- g920f_359937060904505_r58g408w6fl.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed |
The Following User Says Thank You to MUTUAL For This Useful Post: |
06-10-2015, 08:06 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Try to re-flash the phone and repeat "Write Cert" operation. Also, Try to re-install FTDI drivers (http://octoplusbox.com/files/drivers...rs_2.08.24.zip), try to use different C3300k/C3303k cables for connection. |
06-10-2015, 18:28 | #3 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @MUTUAL, try this: Block battery's proper contact by using a tape, connect the phone to Box via Samsung Micro UART C3300k/C3303k cable and write the IMEI Certificate w/o this long Path...put only the Cert in Desktop... NOTE: if too not work: Ceck resistor if is 525/30K if yes try changing with 516/7K resistor, 100% you cable now is working...and with all version of Octopus Sw...tested by me many times BR allumts |
06-11-2015, 04:24 | #4 (permalink) |
Member: 160928 Status: Offline Thanks Meter: 338 | g920f trying writ cert file always fail Quote: you can not remove battery on s6 bro its hard u can remove but its hard if need to do like this i prefer adb method better n easy Can u show me which register u talking about plz ? Last edited by MUTUAL; 06-11-2015 at 04:49. |
06-11-2015, 04:30 | #5 (permalink) |
Insane Poster Join Date: Aug 2009 Location: Manila,Philippines
Member: 1093471 Status: Offline Thanks Meter: 25 | Flash S6 to official firmware then root then wipe security then write cert done Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\07-06-2015_12-09-08.log" created (6/7/2015 12:09:10 PM). ERROR : 6/7/2015 12:09:12 PM > Access violation at address 0094A4EC in module 'OctoplusSamsung.exe'. Read of address 00000004 INFO : 6/7/2015 12:09:13 PM > Set up system language English (file: English.ini) INFO : 6/7/2015 12:09:14 PM > Welcome to Octoplus/Octopus Box Samsung software version 1.9.7 INFO : 6/7/2015 12:09:14 PM > ----------------------------------------------------------------------------------- INFO : 6/7/2015 12:09:14 PM > To connect SM-G313HZ phone you have to perform the following steps: INFO : 6/7/2015 12:09:14 PM > 1. Disconnect USB cable from phone. INFO : 6/7/2015 12:09:14 PM > 2. Go to Menu->Settings->More->About Device. INFO : 6/7/2015 12:09:14 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 6/7/2015 12:09:14 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 6/7/2015 12:09:14 PM > 5. Turn on "USB Debugging" option. INFO : 6/7/2015 12:10:36 PM > ----------------------------------------------------------------------------------- INFO : 6/7/2015 12:10:36 PM > To connect SM-G920F phone you have to perform the following steps: INFO : 6/7/2015 12:10:36 PM > 1. Disconnect USB cable from phone. INFO : 6/7/2015 12:10:36 PM > 2. Go to Menu->Settings->More->About Device. INFO : 6/7/2015 12:10:36 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 6/7/2015 12:10:36 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 6/7/2015 12:10:36 PM > 5. Turn on "USB Debugging" option. INFO : 6/7/2015 12:10:55 PM > ----------------------------------------------------------------------------------- INFO : 6/7/2015 12:10:55 PM > Platform: Samsung Android INFO : 6/7/2015 12:10:55 PM > Selected port: COM293 INFO : 6/7/2015 12:10:55 PM > Selected model: SM-G920F WARN : 6/7/2015 12:10:57 PM > Please, press "OK" button on the phone to allow USB debugging.. WARN : 6/7/2015 12:11:00 PM > Please, press "OK" button on the phone to allow USB debugging.. INFO : 6/7/2015 12:11:00 PM > Detected phone model: SM-G920F INFO : 6/7/2015 12:11:00 PM > Firmware compiled date: Sat Mar 28 19:51:21 KST 2015 INFO : 6/7/2015 12:11:01 PM > PDA version: G920FXXU1AOCV INFO : 6/7/2015 12:11:01 PM > CSC version: G920FITV1AOCN INFO : 6/7/2015 12:11:02 PM > SW version: G920FXXU1AOCW INFO : 6/7/2015 12:11:03 PM > Phone IMEI: Unknown INFO : 6/7/2015 12:11:04 PM > Phone SN: RF8G4198MCF INFO : 6/7/2015 12:11:04 PM > Android version: 5.0.2 (LRX22G) INFO : 6/7/2015 12:11:04 PM > Checking Root: INFO : 6/7/2015 12:11:07 PM > Phone is Rooted. INFO : 6/7/2015 12:11:08 PM > Reading security backup, please wait... INFO : 6/7/2015 12:11:40 PM > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G920F-Unknown07-06-2015_12-10-55-.asec file INFO : 6/7/2015 12:11:40 PM > Wiping EFS... INFO : 6/7/2015 12:11:46 PM > EFS wipe successfully WARN : 6/7/2015 12:11:47 PM > Phone will restart now. Please don't disconnect cable! INFO : 6/7/2015 12:16:26 PM > ----------------------------------------------------------------------------------- INFO : 6/7/2015 12:16:26 PM > Platform: Samsung Android INFO : 6/7/2015 12:16:26 PM > Selected port: COM293 INFO : 6/7/2015 12:16:26 PM > Selected model: SM-G920F WARN : 6/7/2015 12:16:27 PM > Please, press "OK" button on the phone to allow USB debugging.. WARN : 6/7/2015 12:16:29 PM > Please, press "OK" button on the phone to allow USB debugging.. INFO : 6/7/2015 12:16:30 PM > Detected phone model: SM-G920F INFO : 6/7/2015 12:16:30 PM > Firmware compiled date: Sat Mar 28 19:51:21 KST 2015 INFO : 6/7/2015 12:16:30 PM > PDA version: G920FXXU1AOCV INFO : 6/7/2015 12:16:31 PM > CSC version: G920FITV1AOCN INFO : 6/7/2015 12:16:31 PM > SW version: G920FXXU1AOCW INFO : 6/7/2015 12:16:32 PM > Phone IMEI: Unknown INFO : 6/7/2015 12:16:33 PM > Phone SN: RF8G4198MCF INFO : 6/7/2015 12:16:33 PM > Android version: 5.0.2 (LRX22G) INFO : 6/7/2015 12:16:33 PM > Checking Root: INFO : 6/7/2015 12:16:34 PM > Phone is Rooted. INFO : 6/7/2015 12:16:34 PM > Reading security backup, please wait... INFO : 6/7/2015 12:17:05 PM > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G920F-Unknown07-06-2015_12-16-26-.asec file INFO : 6/7/2015 12:17:05 PM > Wiping EFS... INFO : 6/7/2015 12:17:05 PM > EFS wipe successfully WARN : 6/7/2015 12:17:05 PM > Phone will restart now. Please don't disconnect cable! INFO : 6/7/2015 12:17:14 PM > ----------------------------------------------------------------------------------- INFO : 6/7/2015 12:17:14 PM > Platform: Samsung Android INFO : 6/7/2015 12:17:14 PM > Selected port: COM293 INFO : 6/7/2015 12:17:14 PM > Selected model: SM-G920F WARN : 6/7/2015 12:17:14 PM > Please, press "OK" button on the phone to allow USB debugging.. WARN : 6/7/2015 12:17:16 PM > Please, press "OK" button on the phone to allow USB debugging.. INFO : 6/7/2015 12:17:18 PM > Detected phone model: SM-G920F INFO : 6/7/2015 12:17:18 PM > Firmware compiled date: Sat Mar 28 19:51:21 KST 2015 INFO : 6/7/2015 12:17:18 PM > PDA version: G920FXXU1AOCV INFO : 6/7/2015 12:17:19 PM > CSC version: G920FITV1AOCN INFO : 6/7/2015 12:17:20 PM > SW version: G920FXXU1AOCW INFO : 6/7/2015 12:17:21 PM > Phone IMEI: Unknown INFO : 6/7/2015 12:17:21 PM > Phone SN: RF8G4198MCF INFO : 6/7/2015 12:17:21 PM > Android version: 5.0.2 (LRX22G) INFO : 6/7/2015 12:17:21 PM > Checking Root: INFO : 6/7/2015 12:17:22 PM > Phone is Rooted. INFO : 6/7/2015 12:17:22 PM > Reading security backup, please wait... INFO : 6/7/2015 12:17:54 PM > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G920F-Unknown07-06-2015_12-17-14-.asec file INFO : 6/7/2015 12:17:54 PM > Wiping EFS... INFO : 6/7/2015 12:18:01 PM > EFS wipe successfully WARN : 6/7/2015 12:18:02 PM > Phone will restart now. Please don't disconnect cable! INFO : 6/7/2015 12:19:27 PM > ----------------------------------------------------------------------------------- INFO : 6/7/2015 12:19:27 PM > To connect SM-G900F phone you have to perform the following steps: INFO : 6/7/2015 12:19:27 PM > 1. Disconnect USB cable from phone. INFO : 6/7/2015 12:19:27 PM > 2. Go to Menu->Settings->More->About Device. INFO : 6/7/2015 12:19:27 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 6/7/2015 12:19:27 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 6/7/2015 12:19:27 PM > 5. Turn on "USB Debugging" option. INFO : 6/7/2015 12:19:27 PM > 6. Go to dial window. INFO : 6/7/2015 12:19:27 PM > 7. Enter "*#0808#" number. INFO : 6/7/2015 12:19:27 PM > 8. Select "DM+Modem+ADB". INFO : 6/7/2015 12:19:27 PM > 9. Press Home button. INFO : 6/7/2015 12:19:27 PM > 10. Go to dial window. INFO : 6/7/2015 12:19:27 PM > 11. Enter "*#9090#" number. INFO : 6/7/2015 12:19:27 PM > 12. Set "Diag config" to "USB" value. INFO : 6/7/2015 12:19:27 PM > 13. Restart phone. INFO : 6/7/2015 12:19:27 PM > 14. Press "Read Info" in software. INFO : 6/7/2015 12:20:14 PM > ----------------------------------------------------------------------------------- INFO : 6/7/2015 12:20:14 PM > To connect SM-G920F phone you have to perform the following steps: INFO : 6/7/2015 12:20:14 PM > 1. Disconnect USB cable from phone. INFO : 6/7/2015 12:20:14 PM > 2. Go to Menu->Settings->More->About Device. INFO : 6/7/2015 12:20:14 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 6/7/2015 12:20:14 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 6/7/2015 12:20:14 PM > 5. Turn on "USB Debugging" option. INFO : 6/7/2015 12:22:53 PM > ----------------------------------------------------------------------------------- INFO : 6/7/2015 12:22:53 PM > Platform: Samsung Android INFO : 6/7/2015 12:22:53 PM > Selected port: COM293 INFO : 6/7/2015 12:22:53 PM > Selected model: SM-G920F INFO : 6/7/2015 12:23:00 PM > Selected file: D:\Back up\Z3X Files\QCN\S6 S6 Edge\cert-sm-g920f_359845064205185_rf8g410tn3e.cert WARN : 6/7/2015 12:23:02 PM > Perform the following steps: WARN : 6/7/2015 12:23:02 PM > 1. Connect phone via UART cable to the Box. WARN : 6/7/2015 12:23:02 PM > 2. Note: phone screen must be active INFO : 6/7/2015 12:23:02 PM > Connecting to phone, please wait... INFO : 6/7/2015 12:23:07 PM > Found phone on COM9 INFO : 6/7/2015 12:23:07 PM > Phone connected successfully INFO : 6/7/2015 12:23:07 PM > Checking Certificate file... INFO : 6/7/2015 12:23:07 PM > Certificate file successfully checked INFO : 6/7/2015 12:23:07 PM > Writing new phone IMEI... INFO : 6/7/2015 12:23:18 PM > Checking certificate compatibility... INFO : 6/7/2015 12:23:18 PM > Certificate is compatible INFO : 6/7/2015 12:23:24 PM > Certificate has been written successfully INFO : 6/7/2015 12:23:24 PM > Please, restart the phone to apply changes |
06-11-2015, 04:49 | #6 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
Code: Welcome to Octoplus/Octopus Box Samsung software version 1.9.7 ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G920F Operation was canceled Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G920F Selected file: C:\Users\salim\Desktop\cert-sm-g925f_359521062182045 _rf8g40y4nrm.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed and only s6 i connect and only octopus box connected | |
06-11-2015, 07:32 | #8 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @MUTUAL, Listen to me...you issue with this model is Uart cable, replace resistor inside of 525/30K, (ceck first if isn't desoldered one wire), with other of 516/7K max...try and give me if you S6 isn't too not detected from Uart cable... Note: Uart is Autoignition, if you cable not Power on this phone then change this resistor inside....later test with resistor of 516/7K and loock how you power on this phone from power off.... have build other 2 yesterday and are ready for to be used BR allumts |
06-26-2015, 13:05 | #9 (permalink) |
Junior Member Join Date: Sep 2009 Location: Vinnitsa, Ukraine
Member: 1125249 Status: Offline Sonork: 5567776 Thanks Meter: 24 | latest update to 1.9.9 is amazing, write cert via usb has appeared and it works pretty fine, no more need uart cables and resistors thanks Octoplus team, you are the best! |
The Following User Says Thank You to AlexAiS For This Useful Post: |
06-27-2015, 09:18 | #10 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
