01-15-2016, 21:18 | #1 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2124439 Status: Offline Thanks Meter: 23 | G920T Broken Security 35000000....6 IMEI Need Help [Solved] Last edited by Octopus box; 01-18-2016 at 10:37. |
01-16-2016, 12:19 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. In order to repair phone's IMEI, try to write Cert file with the latest Software version. You can use Cert files of SM-G920x models, which are available in the Support Area. |
01-16-2016, 20:41 | #6 (permalink) | |
Member: 2124439 Status: Offline Thanks Meter: 23 | Quote:
01-16-2016, 21:19 | #7 (permalink) |
Member: 2124439 Status: Offline Thanks Meter: 23 | So latest Software Works With New Cert Used a G925T Cert File and boom everything went well and working fine Problem solved Log is Below Welcome to Octoplus/Octopus Box Samsung software version 2.1.7 ----------------------------------------------------------------------------------- To connect SM-N910V phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G920T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM54 Selected model: SM-G920T Selected file: C:\Users\Carlos\Desktop\Phone Stuff\Phone Stuff\CERT Files\Samsung Galaxy S6 Edge\Paid\T-Mobile\SM- G925T_R58G41F377A_359523061883557_24-6-2015_19-13-28 (1).cert Detected phone model: SM-G920T Firmware compiled date: Fri Aug 28 15:24:52 KST 2015 PDA version: G920TUVU2DOH6 CSC version: G920TTMB2DOH6 SW version: G920TUVU2DOH6 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920T-Unknown16-01-2016_11-43-23-.asec file Checking Certificate file... Certificate file successfully checked Deactivating MSL... Executing exploit... Exploit has been executed successfully Certificate has been written successfully Please, restart the phone to apply changes |
The Following User Says Thank You to RexFour For This Useful Post: |
