10-12-2016, 18:15 | #1 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1870650 Status: Offline Thanks Meter: 12 | G920T1 FRP Unlock Help plz I tried to unlock FRP on G920T1 but Can't Problem is ADB can't enable... Octoplus can't recognize the phone, even Odin...so I can't flash and anything. How can I enable adb with FRP locked phone? Please Help. Thanks |
10-13-2016, 07:49 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. To remove FRP lock You can try to do the next: I. 1) Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select Combination firmware, un-check partitions except "boot.img"). 2) Perform "Reset FRP" operation in Software. II. 1) Write Full Combination Firmware. 2) Go to "Developer Options" in phone Settings. 3) Check "Enable OEM unlock" option. 4) Make Factory Data Reset. 5) Reflash the phone with full stock (orignal) firmware. Note: "boot.img" from Combinataion firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! |
10-15-2016, 20:56 | #3 (permalink) | |
Freak Poster Join Date: Nov 2015 Location: Pakistan/UAE/WorldWide Age: 29
Member: 2488504 Status: Offline Sonork: 100.1663349 Thanks Meter: 210 | g920t & g920t1 remove frp Quote:
DOWNLOAD this engboot https://mega.nz/#!4RkwFRCK!aia2MxdXg...WF-_QgKrILhLYY br GONDAL | |
The Following User Says Thank You to motorola. For This Useful Post: |
