01-10-2017, 07:49 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: DUBAI , PAKISTAN
Member: 888420 Status: Offline Sonork: 100.1611861 Thanks Meter: 394 | G925A Unlock Error 6.0.1 ----------------------------------------------------------------------------------- To connect SM-G925A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G925A Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G925A Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G925A Firmware compiled date: Fri Oct 7 13:52:05 KST 2016 PDA version: G925AUCS5DPJ1 CSC version: G925AATT5DPJ1 SW version: G925AUCS5DPJ1 Phone SN: R38G40DNN9A Android version: 6.0.1 (MMB29K) Sales code: ATT Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2016-10-01 Codename: zerolteuc Performed by 2.4.7 Software version. Platform: Samsung Android Selected port: COM4 Selected model: SM-G925A Searching for a phone. Please wait... Found phone on COM214 Reading info... Detected phone model: HW Version: SM-G925AZKFATT PDA version: G925AUCS5DPJ1 CSC version: G925AATT5DPJ1 CP version: G925AUCS5DPJ1 Phone SN: R38G40DNN9A Phone IMEI: 357741-06-120088-5 Unlocking phone... Fast Unlock method is not supported for current security settings in your phone! Try to downgrade firmware! Phone unlocking failed Performed by 2.4.7 Software version. Need Solution thnx |
01-10-2017, 09:11 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Your phone has firmware with new type of Security. Please root the phone, then perform "Unlock" operation via ADB. Post here the result. |
01-10-2017, 09:49 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | There are two possible options: 1) On your own risk You can try to write older firmware, or only modem of older firmware. 2) Root the phone, to use new method of unlocking, which works for new Security type via ADB. |
