10-11-2016, 17:01 | #1 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | G925F Downgrade Platform: Samsung Android Selected port: COM505 Selected model: SM-G925F Searching for a phone. Please wait... Found phone on COM505 Reading info... Detected phone model: HW Version: SM-G925FZWAVOD PDA version: G925FXXU4DPHB CSC version: G925FVFG4DPHB CP version: G925FXXU4DPG2 Phone SN: R58H12ZFVYE Phone IMEI: 356421-07-203987-6 Unlocking phone... Phone unlocking failed Performed by 2.3.7 Software version. Hello I am trying to unlock galaxy s6 edge but I keep getting the error, I assume I have to downgrade the handset , which firmware do I need to flash in order to downgrade? any firmware from support will work? regards |
10-11-2016, 17:17 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Your phone has one of the latest firmwares, which most likely causes the problem. You should try to write older (by release date) firmware. |
10-11-2016, 18:02 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Yes, You can try to write any older firmware (with the same Android version, but with older release date), but we can't guarantee, that phone will accept it. |
10-12-2016, 13:26 | #6 (permalink) |
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | <OSM> G925FXXS3DPE1_G925FVFG3DPC1_G925FXXS3DPC2_HOME.tar .md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/025> Odin engine v(ID:3.1005).. <ID:0/025> File analysis.. <ID:0/025> SetupConnection.. <ID:0/025> Initialzation.. <ID:0/025> Get PIT for mapping.. <ID:0/025> Firmware update start.. <ID:0/025> SingleDownload. <ID:0/025> boot.img <ID:0/025> NAND Write Start!! <ID:0/025> cache.img <ID:0/025> cm.bin <ID:0/025> FAIL! <ID:0/025> <ID:0/025> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/025> Removed!! |
10-12-2016, 13:51 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Phone doesn't accept the firmware. Try to write different older (by release date) firmwares. |
