08-14-2015, 18:52 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | g925f flash error i try to flash with the same version Please put the phone into Download Mode and connect USB cable. To put SM-G925F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... Writing Firmware Failed |
08-14-2015, 19:36 | #3 (permalink) |
Freak Poster Join Date: Mar 2009 Location: morocco Age: 38
Member: 986038 Status: Offline Thanks Meter: 43 | lock here ybe hulp you http://forum.gsmhosting.com/vbb/f777...ailed-1951299/ |
The Following User Says Thank You to aichi-gsm For This Useful Post: |
