08-22-2016, 15:59 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: iran
Member: 2497933 Status: Offline Thanks Meter: 7 | g925f imei 350000000000006 [Solved] I want to write cert and cert succesfully write. but imei does not change. Welcome to Octoplus/Octopus Box Samsung software version 2.3.2 ----------------------------------------------------------------------------------- To connect SM-G925F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925F Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G925F Firmware compiled date: Thu Jul 21 20:26:53 KST 2016 PDA version: G925FXXS4DPGK CSC version: G925FOJV3DPB4 SW version: unknown Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos7420 HW Modem: unknown Codename: zeroltexx Performed by 2.3.2 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925F Selected file: C:\Users\mehrdad\Desktop\sssssssssssssssssssss \cert-sm-g925f_359523060147293_r58g30acfkx.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G925F Firmware compiled date: Thu Jul 21 20:26:53 KST 2016 PDA version: G925FXXS4DPGK CSC version: G925FOJV3DPB4 SW version: unknown Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos7420 HW Modem: unknown Codename: zeroltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G925F-Unknown22-08-2016_17-27-35-.asec file Checking Certificate file... Certificate file successfully checked Deactivating MSL... Executing exploit... Exploit has been executed successfully Performed by 2.3.2 software version Last edited by Octopus box; 02-24-2018 at 10:58. |
08-22-2016, 16:24 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. As You can see from Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair EFS" and "Write Cert" operations. It is not possible to repair IMEI, if phone's modem part is damaged. | |
08-22-2016, 17:03 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We understand You, but unfortunately no other solution for such problem. |
08-22-2016, 17:45 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You should use different available firmwares. |
08-24-2016, 09:12 | #7 (permalink) |
Member: 2497933 Status: Offline Thanks Meter: 7 | i flashed this phone with nine 4 file firmwares without bootloader.with bootloader phone shows binary error.only uae firmware flashed with bootlader.also smart switch flash phone with uae firmware. in some firmware,phone hanged on logo.and in other firmware baseband and imei are unknown. with all firmware I scaned phone in octoplus but still sw version and hw modem is unknown. Last edited by mehrfar62; 08-24-2016 at 09:18. |
08-24-2016, 10:18 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | If after writing of all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem. Quote:
08-24-2016, 10:51 | #9 (permalink) |
Member: 2497933 Status: Offline Thanks Meter: 7 | after flash with smart switch phone has baseband and imei is 350000000000006 but now that i flashed this phone with another firmware , baseband and imei are unknown. another question : flashing the phone without bootloader does not create a problem ? rooting phone not solved the hang on logo Last edited by Octopus box; 08-24-2016 at 15:34. |
08-24-2016, 11:26 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | If phone is not booting after You've wrote a firmware without bootloaders, then the problem is most likely caused by it. |
08-24-2016, 12:18 | #11 (permalink) |
Member: 2497933 Status: Offline Thanks Meter: 7 | after write efs with odin and repair efs with octoplus phone shows this log : phone is uae firmware ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925F To put SM-G925F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Performed by 2.3.2 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925F Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G925F Firmware compiled date: Thu Jul 21 20:26:53 KST 2016 PDA version: G925FXXS4DPGK CSC version: G925FOJV3DPB4 SW version: G925FXXS4DPG3 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zeroltexx Performed by 2.3.2 software version now write cert : ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925F Selected file: C:\Users\mehrdad\Desktop\sssssssssssssssssssss \cert-sm-g925f-rf8g32f6w1t_359521061219780.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G925F Firmware compiled date: Thu Jul 21 20:26:53 KST 2016 PDA version: G925FXXS4DPGK CSC version: G925FOJV3DPB4 SW version: unknown Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos7420 HW Modem: unknown Codename: zeroltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G925F-Unknown24-08-2016_15-52-26-.asec file Checking Certificate file... Certificate file successfully checked Deactivating MSL... Executing exploit... Exploit has been executed successfully Performed by 2.3.2 software version Last edited by Octopus box; 08-24-2016 at 15:34. |
08-24-2016, 13:10 | #12 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | What operations You've performed with the phone before writing a Cert file? As You can see from Software log, phone modem is correct after reflashing: Quote:
08-24-2016, 13:37 | #13 (permalink) |
Member: 2497933 Status: Offline Thanks Meter: 7 | i write efs with odin and repair efs with octoplus.wih this steps imei and baseband and sw version and hw modem are correct. then downgrade modem to 5.1.1 and finally write cert. but after write cert imei does not change. |
08-24-2016, 13:50 | #14 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | As You can see, modem gets damaged, after downgrading: Quote:
08-24-2016, 14:55 | #15 (permalink) |
Member: 2497933 Status: Offline Thanks Meter: 7 | Platform: Samsung Android Selected port: COM1 Selected model: SM-G925F Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G925F Firmware compiled date: Thu Jul 21 20:26:53 KST 2016 PDA version: G925FXXS4DPGK CSC version: G925FOJV3DPB4 SW version: G925FXXS4DPG3 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zeroltexx Performed by 2.3.2 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925F Selected file: C:\Users\mehrdad\Desktop\EFS_CERT_G925F \EFS_CERT_G925F\SM-G925F_RF8G80XYP8P_352564074396697_20- 12-2015_15-8-4.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G925F Firmware compiled date: Thu Jul 21 20:26:53 KST 2016 PDA version: G925FXXS4DPGK CSC version: G925FOJV3DPB4 SW version: G925FXXS4DPG3 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zeroltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G925F-Unknown24-08-2016_18-18-58-.asec file Checking Certificate file... Certificate file successfully checked Deactivating MSL... Executing exploit... Executing exploit failed Writing Certificate failed Performed by 2.3.2 software version |
