01-12-2016, 22:19 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: cluj romania
Member: 185422 Status: Offline Thanks Meter: 41 | g925f [Solved] i try to write firmware an i have this error: Please put the phone into Download Mode and connect USB cable. To put SM-G925F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... Writing Firmware Failed always at 42% best regards Last edited by Octopus box; 01-16-2016 at 14:59. |
01-13-2016, 10:26 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please install the latest Software version and try to write "G925FXXU3COJ1_G925FOJP3COJ1_KSA_Android_5.1.1 " firmware from the Support Area. Post here result and full Software log of the operation. |
01-13-2016, 12:02 | #3 (permalink) |
Member: 185422 Status: Offline Thanks Meter: 41 | Welcome to Octoplus/Octopus Box Samsung software version 2.1.7 ----------------------------------------------------------------------------------- To connect SM-G925F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: G925FXXU3COJ1_G925FOJP3COJ1 _KSA_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G925F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... Writing Firmware Failed same problem at 42% phone was in good condition but after unlock with "another" tool is with baseband and imei null. all i have is efs backup from z3x. with odin and software without bootloader phone is alive but no imei and baseband. best regards |
01-13-2016, 12:27 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to write EFS backup back into the phone. If problem with IMEI/Baseband will persist - try to write different Android 5.1.1 firmwares one by one. |
01-16-2016, 14:25 | #8 (permalink) |
Member: 185422 Status: Offline Thanks Meter: 41 | succesfull 1.write G925FXXU3COI9_G925FBTU3COJ1_G925FXXU3COI9_HOME.tar after that phone hang at first logo 2 write root from support voila phone is working and have imei with 0006 at the end but phone work best regards |
