02-21-2016, 09:33 | #1 (permalink) |
No Life Poster Join Date: Sep 2012 Location: Ghana
Member: 1809548 Status: Offline Sonork: mysty619/100.167036 Thanks Meter: 120 | g925p reboot problem after flash this is log To connect SM-G925P phone you have to perform the following steps: INFO : 2/21/2016 3:21:06 AM > 1. Disconnect USB cable from phone. INFO : 2/21/2016 3:21:06 AM > 2. Go to Menu->Settings->More->About Device. INFO : 2/21/2016 3:21:06 AM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 2/21/2016 3:21:06 AM > 4. Go to Menu->Settings->More->Developer options. INFO : 2/21/2016 3:21:06 AM > 5. Turn on "USB Debugging" option. INFO : 2/21/2016 3:21:23 AM > Selected firmware file: G925PVPU3BOJ7_G925PSPT3BOJ7_SPR_Android_5.1.1.oct WARN : 2/21/2016 3:24:46 AM > Please put the phone into Download Mode and connect USB cable. WARN : 2/21/2016 3:24:46 AM > To put SM-G925P into Download Mode, You have to perform the following steps: WARN : 2/21/2016 3:24:46 AM > 1. Reconnect the battery. WARN : 2/21/2016 3:24:46 AM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 2/21/2016 3:24:46 AM > 3. When phone turns on, press "Volume+" key. INFO : 2/21/2016 3:24:47 AM > Found phone on INFO : 2/21/2016 3:24:47 AM > Firmware write started. INFO : 2/21/2016 3:24:47 AM > Writing BOOTLOADER section... INFO : 2/21/2016 3:24:49 AM > BOOTLOADER section has been written successfully. INFO : 2/21/2016 3:24:49 AM > Writing CM section... INFO : 2/21/2016 3:24:51 AM > CM section has been written successfully. INFO : 2/21/2016 3:24:51 AM > Writing BOOT section... INFO : 2/21/2016 3:24:55 AM > BOOT section has been written successfully. INFO : 2/21/2016 3:24:55 AM > Writing RECOVERY section... INFO : 2/21/2016 3:25:00 AM > RECOVERY section has been written successfully. INFO : 2/21/2016 3:25:00 AM > Writing SYSTEM section... INFO : 2/21/2016 3:31:50 AM > SYSTEM section has been written successfully. INFO : 2/21/2016 3:31:50 AM > Writing CACHE section... INFO : 2/21/2016 3:31:57 AM > CACHE section has been written successfully. INFO : 2/21/2016 3:31:57 AM > Writing RADIO section... INFO : 2/21/2016 3:32:05 AM > RADIO section has been written successfully. INFO : 2/21/2016 3:32:05 AM > Firmware writing successfully completed. INFO : 2/21/2016 3:32:05 AM > Performed by 2.2.1 software version Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\21-02-2016_03-20-30.log" closed (2/21/2016 3:50:48 AM). please help team |
02-21-2016, 12:35 | #2 (permalink) |
Freak Poster Join Date: May 2010 Location: Egypt Age: 33
Member: 1298419 Status: Offline Sonork: 100.1672105 Thanks Meter: 69 | Flash different full firmware via odin , Then do ''Factory Reset'' from recovery , Remove the battery for 5 sec and enter normal mode. |
