03-13-2016, 21:34 | #1 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2070167 Status: Offline Thanks Meter: 4 | G925T DOJC 5.1.1 Octoplus unlock Executing exploit failed.. [Solved] Selected port: COM29 Selected model: SM-G925T Can't kill external ADB references. Please, close all programs that use ADB server. Detected phone model: SM-G925T Firmware compiled date: Mon Nov 30 10:59:44 KST 2015 PDA version: G925TUVS3DOJC CSC version: G925TTMB3DOJC SW version: G925TUVS3DOJC Phone SN: R58G515B9ZM Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as (I had to delete this part because the system is considering it as a link & giving a message saying posting a link is not allowed ...) Deactivating MSL... Executing exploit... Executing exploit failed Reading Certificate failed Performed by 2.2.2 software version I'm having a problem unlocking S6 Edge G925TUVS3DOJC version with Octoplus Software Version V2.2.2. I downloaded the the Sboot file from support area as instructed but I'm still getting the same error Executing exploit..., Executing exploit failed. I had the same issue on Note 4 N910T on previous version and unlocked successfully with Octoplus V2.2.2. Is there any work around or trick on the G925T DOJC version? I'll appreciate any help. Last edited by Octopus box; 03-15-2016 at 10:53. |
03-13-2016, 21:49 | #2 (permalink) |
Freak Poster Join Date: May 2006 Location: USA
Member: 280098 Status: Offline Thanks Meter: 62 | its working fine with me but yes there is work around that Download & flash this modem. Download & flash this sboot. when done unlocking or repairing you can flash the OJC firmware or just the modem & sboot again. repeat unlock operation & let me know P.S. usually this happens when rooting with Unikernel try rooting with CF-Auto Root |
The Following 2 Users Say Thank You to DaDa22 For This Useful Post: |
03-14-2016, 11:23 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please remove SIM card from the phone and repeat "Write Cert" operation. If problem will remain the same - please do the next: 1. Make Factory Reset and reflash the phone. 2. Root the phone with CF Auto Root. 3. Repeat "Write Cert" operation. Post here result and full Software log of performed operations. |
10-17-2016, 07:39 | #6 (permalink) |
Insane Poster Join Date: Apr 2013
Member: 1909558 Status: Offline Thanks Meter: 29 | sm-g928c unlock failed octoplus team plz kindly help me for unlock sm-g928c Platform: Samsung Android Selected port: COM1 Selected model: SM-G928C Detected phone model: SM-G928C Firmware compiled date: Fri Sep 9 16:05:36 KST 2016 PDA version: G928CXXS3BPIA CSC version: G928COJV3BPH9 SW version: G928FXXU3BPH9 Phone SN: R58GB0Y8HVZ Android version: 6.0.1 (MMB29K) Sales code: KSA Country: KSA HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zenltejv Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G928C-Unknown17-10-2016_12-07-31-.asec file Deactivating MSL... Executing exploit... Executing exploit failed Phone unlocking failed Performed by 2.3.8 Software version. |
10-17-2016, 08:30 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Your phone has one of the latest firmwares. In latest firmwares Samsung closed "hole", which were allowing to process the phones. You can try to reflash the phone with older (by release date) firmware, then try to make "Unlock" again. |
10-17-2016, 10:11 | #8 (permalink) |
Member: 1909558 Status: Offline Thanks Meter: 29 | boss Your phone has one of the latest firmwares. In latest firmwares Samsung closed "hole", which were allowing to process the phones. You can try to reflash the phone with older (by release date) firmware i dn"t understand what do u mean with older (by release date) firmware now set firmware version marsmallow 6.0.1 older means lollipop 5.1.1 i can reflash or marsmallow 6.0.1 relese date older ok however how to check mobile firmware relese date plz boss explain me |
10-17-2016, 10:22 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | You can check release dates of firmwares on SamMobile. |
