10-20-2016, 10:28 | #3 (permalink) | |
Freak Poster Join Date: Jul 2013
Member: 1987780 Status: Offline Sonork: 100.1668635 Thanks Meter: 8 | Quote:
Selected firmware file: combination_fa51_g928cxxu2aok1_cl5994902 _qb7252768.oct Please put the phone into Download Mode and connect USB cable. To put SM-G928C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing Firmware Failed | |
The Following User Says Thank You to aboelgasim For This Useful Post: |
10-20-2016, 10:43 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You need to write only "boot.img" partition via "Advanced Mode". No need to write full firmware. Try to do it and post here the result. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
10-21-2016, 15:09 | #5 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Egypt Age: 38
Member: 534871 Status: Offline Sonork: 100.1607626 Thanks Meter: 302 | after write boot only phone hang on logo it is frp lock and dm verficatin failed any help plz ? |
The Following User Says Thank You to hala_gsm_egypt For This Useful Post: |
10-21-2016, 15:20 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please use the latest Software version: http://forum.gsmhosting.com/vbb/f684...cksum-2146805/ Quote:
10-24-2016, 20:03 | #7 (permalink) | |
any combination file failed | |
10-25-2016, 07:21 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You need to try to write another Combination firmware. Most likely the one that You've used is not compatible with current phone firmware. |
10-31-2016, 13:42 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | All Combination firmwares, which we have at the moment, are available in "Samsung/COMBINATION" folder of the Support Area. When we manage to find more firmwares for this model, files will be available in mentioned folder as well. |
