01-11-2017, 03:09 | #1 (permalink) |
Major Poster Join Date: Apr 2007
Member: 481573 Status: Offline Thanks Meter: 46 | G928C/G928F security B:3 FRP & DRK 1000% solution certainly the solution is with combination file but many have problem with compatibility of this only combination file available you can find it here and it's for the two models https://firmware.gem-flash.com/index...e-info&id=8588 what we need now is to flash your phone with this firmware i now it's for g928f but it will work with g928c also: https://www.**************/firmwares...FWIN3BPJ3_WIN/ if the link not work make search for G928FWIN3BPJ3 in sammobile so first flash G928FXXU3BPJ3 and after this flash combination you are done now activate oem in developper mode and your frp is turn off now if your phone is G928C you need to flash it again with original firmware last version sure but you need to select advanced mode and uncheck hiden from firmware for G928F you can flash again the G928FXXU3BPJ3 and also uncheck hiden from firmware all is down now you have to repair DRK with OCTOPUS this solution is tested in 5 phones and it will work 100000% |
The Following 3 Users Say Thank You to diabletina For This Useful Post: |
