10-13-2016, 06:06 | #1 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1206897 Status: Offline Sonork: Aleandros Thanks Meter: 34 | G928F FRP remove with sboot_G928F_OJ5 |
The Following User Says Thank You to NAVAKO For This Useful Post: |
10-13-2016, 08:08 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Problem with witing of Sboot can occur if phone has one of most recent firmwares. To remove FRP lock on such devices You can try to do the next: I. 1) Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select Combination firmware, un-check partitions except "boot.img"). 2) Perform "Reset FRP" operation in Software. II. 1) Write Full Combination Firmware. 2) Go to "Developer Options" in phone Settings. 3) Check "Enable OEM unlock" option. 4) Make Factory Data Reset. 5) Reflash the phone with full stock (orignal) firmware. Note: "boot.img" from Combinataion firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! |
10-13-2016, 23:56 | #3 (permalink) |
No Life Poster Join Date: Oct 2004 Location: italy
Member: 85139 Status: Offline Thanks Meter: 68 | Welcome to Octoplus/Octopus Box Samsung software version 2.3.9 ----------------------------------------------------------------------------------- To connect SM-G928F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: G928FXXS2BPE2_G928FITV2BPB6 _ITV_Android_6.0.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G928F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing CM section... CM section has been written successfully. Writing Firmware Failed Performed by 2.3.9 Software version. HELP |
10-14-2016, 01:37 | #4 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
The Following User Says Thank You to CHANDARAKK For This Useful Post: |
10-14-2016, 08:20 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Problem with reset of FRP lock can occur if phone has one of the latest firmwares. Samsung disabled ability to remove FRP lock in latest firmwares. There are few methods, of how to reset FPR on phones with latest firmwares: I.
II.
III.
Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! If neither of these methods helps, or necessary files are missing, You can use Factory Reset FRP Service. |
