03-22-2017, 18:02 | #1 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | G928F Modem File Code: Platform: Samsung Android Selected port: COM805 Selected model: SM-G928F Searching for a phone. Please wait... Found phone on COM805 Reading info... Detected phone model: SM-G928F HW Version: SM-G928FZKAO2U PDA version: G928FXXS3BQA7 CSC version: G928FTEF3BPJ2 CP version: G928FXXU3BQA1 Phone SN: R38G902TDSK Phone IMEI: 352720-07-960582-7 Reading HWID... Could not read data from phone! Try to downgrade modem! Read codes failed Performed by 2.4.9 Software version. regards |
03-23-2017, 08:57 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Your phone has firmware with new type of Security. To unlock the phone You should root it, then perform "Read Codes"/"Unlock" operation via ADB. |
03-23-2017, 12:26 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Unlocking via ADB requires phone to be rooted. On your own risk You can try to write older firmware, or only it's modem via "Advanced Mode" option of "Write Firmware" operation, then make "Read Codes"/"Unlock" operation via Modem Port. Also You can use Factory Unlock service. |
03-24-2017, 19:37 | #6 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Romania Age: 37
Member: 607365 Status: Offline Sonork: 100.1590583 Thanks Meter: 294 | Flash this modem in CP tab with odin then perform read codes without root : CP_G928FXXU3BPJ3_modem |
The Following User Says Thank You to faurionutz For This Useful Post: |
03-25-2017, 19:44 | #7 (permalink) | |
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | Quote:
<ID:0/025> Firmware update start.. <ID:0/025> SingleDownload. <ID:0/025> CP_G928FXXU3BPJ3_modem.bin <ID:0/025> NAND Write Start!! <ID:0/025> Transmission Complete.. <ID:0/025> Now Writing.. Please wait about 2 minutes <ID:0/025> FAIL! <ID:0/025> <ID:0/025> Receive Response from boot-loader <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/025> Removed!! | |
