03-24-2016, 06:23 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Australia
Member: 177568 Status: Offline Thanks Meter: 147 | G928T FRP unlock problem [Solved] Platform: Samsung Android Selected port: COM1 Everything went through ok but it's still locked?? Selected model: SM-G928T To put SM-G928T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..success Performed by 2.2.2 software version ----------------------------------------------------------------------------------- Last edited by Octopus box; 04-04-2016 at 11:22. |
03-24-2016, 11:53 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. Try to write "SBOOT_G928T_OJ5" SBoot file from the Support Area as a firmware, then repeat "Reset FRP/Reactivation/EE" operation. |
03-31-2016, 07:56 | #3 (permalink) | |
Member: 177568 Status: Offline Thanks Meter: 147 | After writing SBOOT_G928T_OJ5" SBoot file, FRP was removed. Just found out phone is locked to T-Mobile. Tried to unlocked but failed: INFO : 30/03/2016 11:15:54 AM > Platform: Samsung Android INFO : 30/03/2016 11:15:54 AM > Selected port: COM300 INFO : 30/03/2016 11:15:54 AM > Selected model: SM-G928T INFO : 30/03/2016 11:15:56 AM > ADB server killed. WARN : 30/03/2016 11:15:57 AM > Please, press "OK" button on the phone to allow USB debugging.. WARN : 30/03/2016 11:16:01 AM > Please, press "OK" button on the phone to allow USB debugging.. INFO : 30/03/2016 11:16:02 AM > Detected phone model: SM-G928T INFO : 30/03/2016 11:16:02 AM > Firmware compiled date: Fri Dec 4 17:37:11 KST 2015 INFO : 30/03/2016 11:16:02 AM > PDA version: G928TUVS2COKC INFO : 30/03/2016 11:16:03 AM > CSC version: G928TTMB2COKC INFO : 30/03/2016 11:16:04 AM > SW version: G928TUVS2COKC INFO : 30/03/2016 11:16:05 AM > Phone SN: R58G9253ADM INFO : 30/03/2016 11:16:05 AM > Android version: 5.1.1 (LMY47X) INFO : 30/03/2016 11:16:05 AM > Checking Root: INFO : 30/03/2016 11:16:06 AM > Phone is Rooted. INFO : 30/03/2016 11:16:06 AM > Reading security backup, please wait... INFO : 30/03/2016 11:16:43 AM > Backup saved as C:\unlocking program\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G928T-Unknown30-03-2016_11-15-54-.asec file INFO : 30/03/2016 11:16:43 AM > Deactivating MSL... INFO : 30/03/2016 11:16:53 AM > Executing exploit... ERROR : 30/03/2016 11:20:44 AM > Executing exploit failed ERROR : 30/03/2016 11:20:44 AM > Phone unlocking failed INFO : 30/03/2016 11:20:57 AM > Performed by 2.2.2 software version Also tried writing new Cert successfully: INFO : 30/03/2016 11:34:26 AM > Platform: Samsung Android INFO : 30/03/2016 11:34:26 AM > Selected port: COM300 INFO : 30/03/2016 11:34:26 AM > Selected model: SM-G928T INFO : 30/03/2016 11:34:28 AM > ADB server killed. WARN : 30/03/2016 11:34:28 AM > Please, press "OK" button on the phone to allow USB debugging.. WARN : 30/03/2016 11:34:32 AM > Please, press "OK" button on the phone to allow USB debugging.. INFO : 30/03/2016 11:34:37 AM > Detected phone model: SM-G928T INFO : 30/03/2016 11:34:37 AM > Firmware compiled date: Fri Dec 4 17:37:11 KST 2015 INFO : 30/03/2016 11:34:38 AM > PDA version: G928TUVS2COKC INFO : 30/03/2016 11:34:38 AM > CSC version: G928TTMB2COKC INFO : 30/03/2016 11:34:39 AM > SW version: G928TUVS2COKC INFO : 30/03/2016 11:34:41 AM > Phone SN: R58G9253ADM INFO : 30/03/2016 11:34:41 AM > Android version: 5.1.1 (LMY47X) INFO : 30/03/2016 11:34:41 AM > Checking Root: INFO : 30/03/2016 11:34:42 AM > Phone is Rooted. INFO : 30/03/2016 11:34:42 AM > Reading security backup, please wait... INFO : 30/03/2016 11:35:18 AM > Backup saved as C:\unlocking program\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G928T-Unknown30-03-2016_11-34-26-.asec file INFO : 30/03/2016 11:35:30 AM > Deactivating MSL... INFO : 30/03/2016 11:35:40 AM > Executing exploit... INFO : 30/03/2016 11:36:20 AM > Exploit has been executed successfully INFO : 30/03/2016 11:36:26 AM > MSL deactivate successfully INFO : 30/03/2016 11:36:26 AM > Reading Certificate... INFO : 30/03/2016 11:36:26 AM > Checking Certificate file... INFO : 30/03/2016 11:36:26 AM > Phone KeyID: 784 INFO : 30/03/2016 11:36:26 AM > Certificate file successfully checked INFO : 30/03/2016 11:36:26 AM > Certificate read successfully INFO : 30/03/2016 11:36:26 AM > Performed by 2.2.2 software version Phone still has message: Network Lock: This device can be remotely unlocked if eligible. Please use the "Device Unlock" application to unlock the device. Make sure the device has an internet connectivity to use the "Device Unlock" application. OK Quote:
03-31-2016, 11:17 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please install the latest Software version, remove SIM card from the phone and repeat "Unlock" operation. Post here the result. |
04-01-2016, 03:50 | #5 (permalink) | |
Member: 177568 Status: Offline Thanks Meter: 147 | ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM300 Selected model: SM-G928T ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G928T Firmware compiled date: Fri Dec 4 17:37:11 KST 2015 PDA version: G928TUVS2COKC CSC version: G928TTMB2COKC SW version: G928TUVS2COKC Phone SN: R58G9253ADM Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\unlocking program\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G928T-Unknown01-04-2016_12-50-11-.asec file Deactivating MSL... Executing exploit... Executing exploit failed Phone unlocking failed Performed by 2.2.3 software version Quote:
04-01-2016, 10:42 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please do the next: 1. Make Factory Reset. 2. Reflash the phone. 3. Root the phone with CF Auto Root. 4. Repeat "Unlock" operation. Post here result and full Software log of performed operations. |
04-04-2016, 04:03 | #7 (permalink) |
Member: 177568 Status: Offline Thanks Meter: 147 | Reflashed with different firmware and unlocked again. All good now. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM300 Selected model: SM-G928T ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G928T Firmware compiled date: Wed Oct 14 15:47:18 KST 2015 PDA version: G928TUVU2COJ5 CSC version: G928TTMB2COJ5 SW version: G928TUVU2COJ5 Phone SN: R58G9253ADM Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\unlocking program\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G928T-Unknown04-04-2016_12-12-56-.asec file Deactivating MSL... Executing exploit... Exploit has been executed successfully Unlocking phone. This can take some time. Please wait... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.3 software version |
04-29-2016, 15:33 | #8 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2533283 Status: Offline Thanks Meter: 0 | hello octopus team i tried Sboot method to remove frp and it is successfully working but i can't use playstore when i put gmail id in it or Samsung id or finger print lock in it after this when i restart it stuck on logo and says custom binary blocked by FRP lock and then i have to same process again please help me with proper solution |
04-29-2016, 16:27 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Perform "Reset FRP/Reactivation/EE" operation again. Then disable FRP lock in phone's Settings. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
