10-15-2016, 03:52 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Australia
Member: 177568 Status: Offline Thanks Meter: 146 | G930F FRP reset, now stuck in recovery -The phone had PIN so I did a hard reset and it turned out it has FRP on. -I tried to remove FRP the normal way by selecting "FRP/Reactivation/EE" and phone got stuck on samsung after file installed from server so it couldn't search for phone. -I successfully flashed G930FXXU1APGO_G930FAUT1APG1_AUT_android_6.0.1.oct but phone goes straight to android recovery. So I select wipe data/factory reset and reboot phone. it goes back to android recovery and at bottom left screen appears "dm-verity verification failed...Need to checkDRK first..." -I also tried to flash combination_g930f_g930fxxu1apb4_boot.oct but afterward, on top left of screen appears "ASV TBL VER=8 ASVTBL, VER2=0, RPMB PROVISIONED " and I can't do "reset RFP" because even after installing combination boot file, ADB is still not activated. - I also tried combination_fa60_g930fxxu1apc6_cl7570560_qb9028627 .oct. but can't finish flashing because of RFP block. What can I do to revive the phone? |
The Following User Says Thank You to mtb116 For This Useful Post: |
10-15-2016, 06:00 | #2 (permalink) |
Freak Poster Join Date: Aug 2016
Member: 2616438 Status: Offline Thanks Meter: 147 | Flash again the normal software 6.0.1 then go again to download mode and flash cf auto root file for your device. Your phone know will boot up normally but you will still face the google account verification Sent from my SM-N920C using Tapatalk |
The Following User Says Thank You to wadda7o For This Useful Post: |
10-15-2016, 09:16 | #3 (permalink) | |||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Quote:
10-17-2016, 08:09 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | You need to remove FRP lock first, then root the phone to temporary fix corrupted DRK. |
10-17-2016, 14:46 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to remove FRP lock, then root the phone to temporary fix corrupted DRK. |
10-27-2016, 02:38 | #8 (permalink) |
Member: 177568 Status: Offline Thanks Meter: 146 | I have tried a few different combinations of firmwares and combination files and boot files. These are the steps (ONLY IN THIS ORDER) that I have tried and it's sort of nearly work for me: 1. Flash G930FXXU1APB4_G930FUUB1APB4 ( phone turns on and stays in recovery mode. if I select "factory wipe and reset and reboot", phone goes back to recovery mode with "dm-verity verification failed... Need to check DRK first..." 2. Then flash combination_g930f_g930fxxu1apb4_boot.oct (phone turns on and stays in logo) 3. Then Flash COMBINATION_G930FXXU1APB4_boot.tar ( phone turns on like normal, like new phone in activation screen BUT it restarts every around 15 seconds) Phone doesn't stay on long enough for me to even try factory remove FRP via your server. This is the closest I can get to revive the phone. Files in step 2 and step 3 seem the same but there is something different in files. Any suggestion pls?? |
10-27-2016, 07:52 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | "boot.img" from Combination firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). You need to find and use another combination firmware. |
