06-01-2017, 15:57 | #1 (permalink) |
Freak Poster Join Date: Dec 2006 Location: POMPEI
Member: 405174 Status: Offline Thanks Meter: 18 | g930f imei fixed... no network after upgrade to android 7 ----------------------------------------------------------------------------------- To connect SM-J320FN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G930F Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G930F Firmware compiled date: Mon Apr 17 17:02:03 KST 2017 PDA version: G930FXXU1DQD7 CSC version: G930FITV1DQD1 SW version: G930FXXU1DQD7 Phone SN: R58H748845K Android version: 7.0 (NRD90M) Sales code: ITV Country: ITALY HW platform: exynos5 HW Chip: exynos8890 HW Modem: SHANNON335 Security patch level: 2017-04-01 Codename: heroltexx Performed by 2.5.2 Software version. |
06-01-2017, 16:00 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. "Repair Network" is a "patch firmware" solution. After writing of any firmware phone goes to initial condition. You can try to make "Repair Network" again, but it is not likely to work for device on Android 7 firmware, unfortunately. To fix the problem we recommend to donwgrade firmware version to Android 6.x, then make "Repair Network". |
06-01-2017, 17:02 | #3 (permalink) |
Member: 405174 Status: Offline Thanks Meter: 18 | The conditions are as follows: PDA version: G930FXXU1DQD7 CSC version: G930FITV1DQD1 SW version: G930FXXU1DQD7 How should I proceed? Which firmware do I have to install imei / efs? |
06-01-2017, 17:58 | #4 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
But NOT killed the market and Advise customers of cannot Update fw or do Factory reset, not think only to make money...is Not correct not advise customer. | |
The Following User Says Thank You to allumts For This Useful Post: |
06-04-2017, 21:37 | #6 (permalink) | |
***REPEAT, ADVISE THAT'S "TEMPORARY SOLUTION", CANNOT "UPDATE FW" or "FACTORY RESET"*** Too much S7/S7 Edge enter in my shop with too much damaged partition, becouse 80% of you think only to take money and NOT do Any BKP and NOT Advise Customer about "LIMITATION"!!!! | |
06-05-2017, 09:13 | #7 (permalink) | |
Member: 405174 Status: Offline Thanks Meter: 18 | Quote:
03-09-2018, 17:39 | #8 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2452554 Status: Offline Thanks Meter: 1 | Need help plz.. SM-G930F no network registered I have downgraded to version 6.0. I tried to operate network repair and it failed several times. Need help please! Please find log below: Platform: Samsung Android Selected port: COM5 Selected model: SM-G930F Detected phone model: SM-G930F Firmware compiled date: Mon Jul 4 11:20:39 KST 2016 PDA version: G930FXXS1APG3 CSC version: G930FDHX1APE1 SW version: G930FXXU1APEQ Phone SN: R58H32ETRRE Android version: 6.0.1 (MMB29K) Sales code: DHR Country: Croatia HW platform: exynos5 HW Chip: exynos8890 HW Modem: SHANNON335 Security patch level: 2016-07-01 SIM 1 status: absent Codename: heroltexx Checking Root: Phone is Rooted. Repairing network. Please wait, this can take some time... An error has occurred on step 2 Repairing network failed. Performed by 2.6.5 Software version. |
03-09-2018, 19:05 | #10 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote: Anyway since betwen operation with 6.0.1 or 7 are TEMPORARY solution, (read above), you for sure have you imei in BLACK LIST, so Isn't enough do only "Repair Network". So, first need of do "IMEI REPAIR" and later "REPAIR NETWORK", will see that all work fine!!!! Use last sw samsung version. | |
03-10-2018, 15:46 | #11 (permalink) |
Member: 2452554 Status: Offline Thanks Meter: 1 | Thanks for your reply. Please you can help me, I have started new thread http://forum.gsmhosting.com/vbb/f684.../#post13012163 |
03-10-2018, 15:47 | #12 (permalink) |
Member: 2452554 Status: Offline Thanks Meter: 1 | Hello thanks for response. Modem file (ENG_MODEM_G930F_2_RA2_for_unlock) was written successfully. Next I did "Reapir IMEI" operation successful, then "Repair Network" operation failed again. Please find log below: Platform: Samsung Android Selected port: COM1 Selected model: SM-G930F Detected phone model: SM-G930F Firmware compiled date: Mon Jul 4 11:20:39 KST 2016 PDA version: G930FXXS1APG3 CSC version: G930FDHX1APE1 SW version: G930FXXU2ARA1 Phone SN: R58H32ETRRE Android version: 6.0.1 (MMB29K) Sales code: DHR Country: Croatia HW platform: exynos5 HW Chip: exynos8890 HW Modem: SHANNON335 Security patch level: 2016-07-01 SIM 1 status: absent Codename: heroltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G930F-R58H32ETRRE-10-03-2018_06-18-40-.asec file Connecting to modem port... Found phone on COM5 Reading data from phone...OK New IMEI: 351246552114567 Writing new phone IMEI... Please make "Repair Network" operation after reboot! IMEI successfully repaired. Performed by 2.6.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G930F Detected phone model: SM-G930F Firmware compiled date: Mon Jul 4 11:20:39 KST 2016 PDA version: G930FXXS1APG3 CSC version: G930FDHX1APE1 SW version: G930FXXU2ARA1 Phone SN: R58H32ETRRE Android version: 6.0.1 (MMB29K) Sales code: DHR Country: Croatia HW platform: exynos5 HW Chip: exynos8890 HW Modem: SHANNON335 Security patch level: 2016-07-01 SIM 1 status: absent Codename: heroltexx Checking Root: Phone is Rooted. Repairing network. Please wait, this can take some time... An error has occurred on step 2 Repairing network failed. Performed by 2.6.5 Software version. |
03-11-2018, 10:58 | #13 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello. Why you have done this BIG error of Upgrade Modem from Binary U1 to U2 where NOT there any solution yet? You had this firmware inside first: Quote:
Write Back U1 modem and repeate all step in post #10 Next time read very carefully what i have suggest you.!!!!! | |
03-12-2018, 12:33 | #14 (permalink) | |
Member: 2452554 Status: Offline Thanks Meter: 1 | Quote:
Thank you Sir. I have followed as you suggested. Same problem, failed error after "Network Repair". I reflashed successfully.. Firmware compiled date: Mon Jul 4 11:20:39 KST 2016 PDA version: G930FXXS1APG3 CSC version: G930FDHX1APE1 SW version: G930FXXU1APEQ | |
03-12-2018, 14:32 | #15 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Cannnot belive that all my G930F/35F with Android 7 FW are done w/o any problem. At first time "Imei Repair" then "Repair Network" all full success. Will be my Fw "Special" for i doing w/o any issue??? Ceck all my Success report about G930/35F and will see!!! One here for Example with Android 7: http://forum.gsmhosting.com/vbb/12799979-post6062.html Last edited by allumts; 03-12-2018 at 14:37. |
