10-10-2018, 16:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | g930fxxs2drc3 frp I have g930fxxs2drc3 - with frp lock. I dont have the uart cable (only z3x c3300k uart cables) so I cant reset using box method is there any other way to reset frp on this model? regards |
10-10-2018, 16:17 | #2 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
here you have the two options if you enter the octopus program and select the help item you find the frp reset methods Method 2. Via ADB (Combination) Enable ADB by writing boot.img partition from combination firmware Click "Reset FRP" button. Connect the phone to PC via Micro USB cable. Follow software instructions (prompts). Second method to Enable ADB: Write full combination firmware. Enable ADB from settings Write stock firmware without "recovery.img", "cache.img", and "userdata" partitions. Last edited by amleto90; 10-10-2018 at 16:23. | |
The Following User Says Thank You to amleto90 For This Useful Post: |
10-10-2018, 16:28 | #4 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | here you find the combination g935f binary 2 COMBINATION_FA60_G935FXXU2ARA1_CL7964511_QB1658130 9_REV00_user_mid_noship.tar.md5.rar Link download: https://androidfilehost.com/?fid=1322778262904016347 e careful to install the combination binary 2 that is compatible with the firmware that you have installed on your phone before damaging the phone, I suggest you install an android firmware 7 with security patch level in January Last edited by amleto90; 10-10-2018 at 16:35. |
10-10-2018, 17:08 | #5 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | sorry, I confused the model and the combination COMBINATION_FA60_G930FXXU2ARA2_CL7964511_QB1658131 6_REV00_user_mid_noship.tar.md5.rar Link Download g930f binary 2 combination: https://drive.google.com/file/d/1VMs...PU6YGi79Q/view |
