02-22-2017, 21:21 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | G935FD android 7 FRP reset I have the set G935FD android 7.0 CSC INS (india). when I frp reset ,phone in logo only... via smart switch i recover the set. So how to reset this frp. Also I tried via quick short cut manager......here not email and password file under google account manager....even I install google account manager 7.0 Could you pls advice me Thanks. |
02-22-2017, 21:55 | #2 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Hello bro downgrade to old 6.0.1 version and try call bug it will work Quote:
IF YOU.LIKE WHAT I POST PRESS❤ THANKS BUTTON | |
The Following User Says Thank You to souma_k For This Useful Post: |
02-23-2017, 08:29 | #4 (permalink) |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | The log INFO : 2/22/2017 8:02:05 PM > Set up system language English (file: English.ini) INFO : 2/22/2017 8:02:05 PM > Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 INFO : 2/22/2017 8:02:12 PM > ----------------------------------------------------------------------------------- INFO : 2/22/2017 8:02:12 PM > To connect SM-G935F phone you have to perform the following steps: INFO : 2/22/2017 8:02:12 PM > 1. Disconnect USB cable from phone. INFO : 2/22/2017 8:02:12 PM > 2. Go to Menu->Settings->More->About Device. INFO : 2/22/2017 8:02:12 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 2/22/2017 8:02:12 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 2/22/2017 8:02:12 PM > 5. Turn on "USB Debugging" option. INFO : 2/22/2017 8:03:35 PM > ----------------------------------------------------------------------------------- INFO : 2/22/2017 8:03:36 PM > Platform: Samsung Android INFO : 2/22/2017 8:03:36 PM > Selected port: COM1 INFO : 2/22/2017 8:03:36 PM > Selected model: SM-G935F WARN : 2/22/2017 8:03:36 PM > Connecting to server... INFO : 2/22/2017 8:03:38 PM > Connecting to server...Ok! INFO : 2/22/2017 8:03:38 PM > Checking resource files... INFO : 2/22/2017 8:03:41 PM > Resource files already downloaded. WARN : 2/22/2017 8:03:41 PM > Please put the phone into Download Mode and connect USB cable. WARN : 2/22/2017 8:03:41 PM > To put SM-G935F into Download Mode, You have to perform the following steps: WARN : 2/22/2017 8:03:41 PM > 1. Reconnect the battery. WARN : 2/22/2017 8:03:41 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 2/22/2017 8:03:41 PM > 3. When phone turns on, press "Volume+" key. INFO : 2/22/2017 8:03:41 PM > Waiting for phone... INFO : 2/22/2017 8:03:41 PM > Firmware write started. INFO : 2/22/2017 8:03:41 PM > Writing Boot section... INFO : 2/22/2017 8:03:46 PM > Boot section has been written successfully. INFO : 2/22/2017 8:03:46 PM > Searching for a phone. Please wait... ERROR : 2/22/2017 8:05:47 PM > timeout ERROR : 2/22/2017 8:05:47 PM > Phone not found. ERROR : 2/22/2017 8:05:47 PM > Operation was failed! INFO : 2/22/2017 8:05:47 PM > Performed by 2.4.7 Software version. |
02-23-2017, 08:57 | #6 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
It has only 7.0 no 7.1 or other but I have G935FD not G935F also in download mode it say G935F Thanks. | |
02-23-2017, 09:00 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,388 | Hello. Unfortunately removal of FRP lock is not supported for devices on Android 7.0 firmwares. You can try to write older firmware, then repeat "Reset FRP" operation. |
02-23-2017, 09:23 | #8 (permalink) | |
Thanks bos. Could you pls advice me that this set is possible to downgrade to 6.0.1 | |
