Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 06-12-2019, 14:48   #1 (permalink)
Member: 2011612
Thanks Meter: 7
G935L android 7.0 U2 stock bootloader needed [Answered]
Hello team. I have samsung g935L blocked by frp. Tried to unlock by octoplus but need do downgrade sboot. Please team i need sboot u2 for g935L. I have no a good connexion to download full stock firmware or combination file. Sory for my bad english. Im french.
Envoyé de mon SM-A600F en utilisant Tapatalk
Old 06-12-2019, 15:01   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 23,921
ello.
Problem with reset of FRP lock can occur if phone has one of the latest firmwares. Samsung disabled ability to remove FRP lock in latest firmwares.
There are few methods, of how to reset FPR on phones with latest firmwares:
I.
Try to write SBoot file of older firmware.
Repeat "Reset FRP/Reactivation/EE" operation.
II.
Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select Combination firmware, un-check partitions except "boot.img").
Perform "Reset FRP" operation in Software.
74957382
III.
Write Full Combination Firmware.
Go to "Developer Options" in phone Settings.
Check "Enable OEM unlock" option.
Make Factory Data Reset.
Reflash the phone with full stock (orignal) firmware.
Note: "boot.img" from Combinataion firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares).
Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk!
If neither of these methods helps, or necessary files are missing, You can use Factory Reset FRP Service.
Old 06-12-2019, 15:26   #3 (permalink)
Member: 2613252
Thanks Meter: 1,047
Hello, link download for g935l eng sBoot binary 2
ENG SBOOT G935LKLU2ARI1*
Download:
ENG SBOOT G935LKLU2ARI1 (ANGLE360.TECH)
The Following User Says Thank You to amleto90 For This Useful Post:
Old 06-12-2019, 15:48   #4 (permalink)
Member: 2011612
Thanks Meter: 7
Download:
Bro link not work
Old 06-12-2019, 15:59   #5 (permalink)
Member: 2613252
Thanks Meter: 1,047
Bro link not work
try to download it from this link, it links you to the download link
However to me the link that I posted to you from pc opens me from mediafire and I can easily download it
https://angle360.tech/?page_id=236
Look:
https://i.postimg.cc/sxY6mNjS/screenshot-315.png
Old 06-12-2019, 16:04   #6 (permalink)
Member: 2011612
Thanks Meter: 7
Tank you. But this file don't brick my phone?
Old 06-12-2019, 16:09   #7 (permalink)
Member: 2613252
Thanks Meter: 1,047
It depends on what firmware you have installed on your phone if it is compatible with sboot binary 2 for g935L
why don't you use the combination for g935l binary 2 install it and then with the ufs memory method via uart cable with octopus you can read the file and then write the stock firmware in 4 files selecting ap, bl, cp, home_csc
Look and read post:
G935L-G935S-G935K model korea combination binary 2 ( Available )
Old 06-12-2019, 16:16   #8 (permalink)
Member: 2011612
Thanks Meter: 7
Tank you bro.
Page generated in 0.33855 seconds with 7 queries
