09-22-2019, 20:18 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: inside forum
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | G950 U Sprint unlocking problem [Solved] During unlock giving msg plz update phone firmware & try again unlocking failed after update security patch from 1/12/2018 to 1/1/2019 still same problem |
09-23-2019, 07:05 | #4 (permalink) |
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | INFO : 2019-09-22 7:55:18 PM > Platform: Samsung Android INFO : 2019-09-22 7:55:18 PM > Selected port: COM40 INFO : 2019-09-22 7:55:18 PM > Selected model: SM-G950U INFO : 2019-09-22 7:55:18 PM > Operation: Unlock WARN : 2019-09-22 7:55:18 PM > Searching for a phone. Please wait... INFO : 2019-09-22 7:55:19 PM > Detected phone model: SM-G950U INFO : 2019-09-22 7:55:19 PM > Firmware compiled date: Wed Jan 2 15:44:50 KST 2019 INFO : 2019-09-22 7:55:19 PM > PDA version: G950USQU5CSA4 INFO : 2019-09-22 7:55:19 PM > CSC version: G950UOYN5CSA4 INFO : 2019-09-22 7:55:19 PM > SW version: G950USQU5CSA4 INFO : 2019-09-22 7:55:20 PM > Phone SN: R28J51P9T2W INFO : 2019-09-22 7:55:20 PM > Android version: 8.0.0 (R16NW) INFO : 2019-09-22 7:55:20 PM > Sales code: SPR INFO : 2019-09-22 7:55:20 PM > Country: USA INFO : 2019-09-22 7:55:20 PM > HW platform: msm8998 INFO : 2019-09-22 7:55:20 PM > HW Chip: MSM8998 INFO : 2019-09-22 7:55:20 PM > HW Modem: MSM8998 INFO : 2019-09-22 7:55:20 PM > Security patch level: 2019-01-01 INFO : 2019-09-22 7:55:20 PM > Warranty Void: 0 INFO : 2019-09-22 7:55:20 PM > SIM 1 status: card io error INFO : 2019-09-22 7:55:20 PM > Codename: dreamqltesq INFO : 2019-09-22 7:55:20 PM > Connecting to modem port... INFO : 2019-09-22 7:55:24 PM > Found phone on COM40 INFO : 2019-09-22 7:55:24 PM > Reading IMEI... INFO : 2019-09-22 7:55:30 PM > OK INFO : 2019-09-22 7:55:30 PM > ----------------------------------------------------------------------------------- WARN : 2019-09-22 7:55:30 PM > Connecting to server... WARN : 2019-09-22 7:55:32 PM > OK INFO : 2019-09-22 7:55:32 PM > Checking smart card... INFO : 2019-09-22 7:55:42 PM > OK INFO : 2019-09-22 7:55:42 PM > Username: mursaleen INFO : 2019-09-22 7:55:42 PM > Authorizing... INFO : 2019-09-22 7:55:44 PM > OK INFO : 2019-09-22 7:55:44 PM > Checking balance... INFO : 2019-09-22 7:55:46 PM > OK INFO : 2019-09-22 7:55:47 PM > Checking operation... INFO : 2019-09-22 7:55:49 PM > OK INFO : 2019-09-22 7:55:49 PM > Your balance: 100 credits. INFO : 2019-09-22 7:55:49 PM > ----------------------------------------------------------------------------------- INFO : 2019-09-22 7:55:49 PM > Sending device information... INFO : 2019-09-22 7:55:53 PM > OK INFO : 2019-09-22 7:56:09 PM > Initializing exploit... INFO : 2019-09-22 7:56:25 PM > OK INFO : 2019-09-22 7:56:25 PM > Checking lock status... WARN : 2019-09-22 7:56:26 PM > Locked INFO : 2019-09-22 7:56:26 PM > Unlocking phone... ERROR : 2019-09-22 7:56:26 PM > Please update phone's firmware and try again! ERROR : 2019-09-22 7:56:27 PM > Phone unlocking failed INFO : 2019-09-22 7:56:27 PM > Performed by 2.8.2.3 Software version. INFO : 2019-09-22 8:02:43 PM > ----------------------------------------------------------------------------------- INFO : 2019-09-22 8:02:43 PM > Connecting to server... INFO : 2019-09-22 8:02:46 PM > Username: mursaleen INFO : 2019-09-22 8:02:46 PM > Authorizing... INFO : 2019-09-22 8:02:48 PM > Checking balance... WARN : 2019-09-22 8:02:51 PM > Your balance: 100 credits. INFO : 2019-09-22 8:02:51 PM > Performed by 2.8.2.3 Software version. |
09-23-2019, 07:12 | #5 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,154 | According software manual please do the next: Quote:
09-23-2019, 08:04 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | You can try to use modem from this G950USQU5ARG4 combination firmware, follow: ""SAMSUNG/COMBINATION/SM-G950U" folder |
09-23-2019, 08:14 | #8 (permalink) |
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | & after write combination need to flash phone with stock firmware which is also not in support area suggest which file can use to flash stock firmware |
09-23-2019, 08:24 | #9 (permalink) | |
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | check this post Quote:
this guy did it with only two files unfortunately second CP file link not working | |
09-23-2019, 08:46 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Please, try to write modem from this G950USQU5ARG4 combination firmware, follow: ""SAMSUNG/COMBINATION/SM-G950U" folder after post here full Software log of Unlock operation |
09-23-2019, 11:27 | #11 (permalink) |
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | After write combination still same problem \COMBINATION_FA70_G950USQU5ARG4_CL13344735_QB18805 722_REV00_user_mid_noship_MULTI_CERT.tar.md5 WARN : 2019-09-23 3:39:47 PM > Please put the phone into Download Mode and connect USB cable. WARN : 2019-09-23 3:39:47 PM > To put SM-G950U into Download Mode, You have to perform the following steps: WARN : 2019-09-23 3:39:47 PM > 1. Power off the phone. WARN : 2019-09-23 3:39:47 PM > 2. Press and hold "Volume-" + "Bixby" + "Power ON" keys. WARN : 2019-09-23 3:39:47 PM > 3. When phone turns on, press "Volume+" key. INFO : 2019-09-23 3:39:47 PM > Found phone on WARN : 2019-09-23 3:39:47 PM > Advanced mode! INFO : 2019-09-23 3:39:51 PM > Firmware write started. INFO : 2019-09-23 3:39:51 PM > Writing ABL section... INFO : 2019-09-23 3:39:51 PM > ABL section has been written successfully. INFO : 2019-09-23 3:39:51 PM > Writing BKSECAPP section... INFO : 2019-09-23 3:39:51 PM > BKSECAPP section has been written successfully. INFO : 2019-09-23 3:39:51 PM > Writing XBL section... INFO : 2019-09-23 3:39:52 PM > XBL section has been written successfully. INFO : 2019-09-23 3:39:52 PM > Writing TZ section... INFO : 2019-09-23 3:39:52 PM > TZ section has been written successfully. INFO : 2019-09-23 3:39:52 PM > Writing HYP section... INFO : 2019-09-23 3:39:52 PM > HYP section has been written successfully. INFO : 2019-09-23 3:39:52 PM > Writing DEVCFG section... INFO : 2019-09-23 3:39:52 PM > DEVCFG section has been written successfully. INFO : 2019-09-23 3:39:52 PM > Writing PMIC section... INFO : 2019-09-23 3:39:52 PM > PMIC section has been written successfully. INFO : 2019-09-23 3:39:52 PM > Writing RPM section... INFO : 2019-09-23 3:39:52 PM > RPM section has been written successfully. INFO : 2019-09-23 3:39:52 PM > Writing CMNLIB section... INFO : 2019-09-23 3:39:52 PM > CMNLIB section has been written successfully. INFO : 2019-09-23 3:39:52 PM > Writing CMNLIB64 section... INFO : 2019-09-23 3:39:52 PM > CMNLIB64 section has been written successfully. INFO : 2019-09-23 3:39:52 PM > Writing KEYMASTER section... INFO : 2019-09-23 3:39:52 PM > KEYMASTER section has been written successfully. INFO : 2019-09-23 3:39:52 PM > Writing APDP section... INFO : 2019-09-23 3:39:52 PM > APDP section has been written successfully. INFO : 2019-09-23 3:39:52 PM > Writing MSADP section... INFO : 2019-09-23 3:39:52 PM > MSADP section has been written successfully. INFO : 2019-09-23 3:39:53 PM > Writing SEC section... INFO : 2019-09-23 3:39:53 PM > SEC section has been written successfully. INFO : 2019-09-23 3:39:53 PM > Writing APNHLOS section... INFO : 2019-09-23 3:39:54 PM > APNHLOS section has been written successfully. INFO : 2019-09-23 3:39:54 PM > Writing STORSEC section... INFO : 2019-09-23 3:39:54 PM > STORSEC section has been written successfully. INFO : 2019-09-23 3:39:54 PM > Writing BOOT section... INFO : 2019-09-23 3:39:55 PM > BOOT section has been written successfully. INFO : 2019-09-23 3:39:55 PM > Writing RECOVERY section... INFO : 2019-09-23 3:39:57 PM > RECOVERY section has been written successfully. INFO : 2019-09-23 3:39:57 PM > Writing SYSTEM section... INFO : 2019-09-23 3:41:35 PM > SYSTEM section has been written successfully. INFO : 2019-09-23 3:41:35 PM > Writing PERSIST section... INFO : 2019-09-23 3:41:36 PM > PERSIST section has been written successfully. INFO : 2019-09-23 3:41:36 PM > Writing MODEM section... INFO : 2019-09-23 3:41:39 PM > MODEM section has been written successfully. INFO : 2019-09-23 3:41:39 PM > Writing DSP section... INFO : 2019-09-23 3:41:40 PM > DSP section has been written successfully. INFO : 2019-09-23 3:41:44 PM > Firmware writing successfully completed. INFO : 2019-09-23 3:41:44 PM > Performed by 2.8.2.3 Software version. INFO : 9/23/2019 3:45:29 PM > ----------------------------------------------------------------------------------- INFO : 9/23/2019 3:45:31 PM > Platform: Samsung Android INFO : 9/23/2019 3:45:31 PM > Selected port: COM1 INFO : 9/23/2019 3:45:31 PM > Selected model: SM-G950U INFO : 9/23/2019 3:45:31 PM > Operation: Unlock WARN : 9/23/2019 3:45:31 PM > Searching for a phone. Please wait... WARN : 9/23/2019 3:45:34 PM > Please, press "OK" button on the phone to allow USB debugging. INFO : 9/23/2019 3:45:35 PM > Detected phone model: SM-G950U INFO : 9/23/2019 3:45:35 PM > Firmware compiled date: Wed Jul 4 11:26:54 KST 2018 INFO : 9/23/2019 3:45:35 PM > PDA version: FA70_G950USQU5ARG4 INFO : 9/23/2019 3:45:35 PM > CSC version: unknown INFO : 9/23/2019 3:45:35 PM > SW version: G950USQU5CRF1 INFO : 9/23/2019 3:45:36 PM > Phone SN: R28J51P9T2W INFO : 9/23/2019 3:45:36 PM > Android version: 7.0 (NRD90M) INFO : 9/23/2019 3:45:36 PM > Sales code: unknown INFO : 9/23/2019 3:45:36 PM > Country: unknown INFO : 9/23/2019 3:45:36 PM > HW platform: msm8998 INFO : 9/23/2019 3:45:36 PM > HW Chip: MSM8998 INFO : 9/23/2019 3:45:36 PM > HW Modem: MSM8998 INFO : 9/23/2019 3:45:36 PM > Security patch level: 2017-02-01 INFO : 9/23/2019 3:45:36 PM > Warranty Void: 0 INFO : 9/23/2019 3:45:36 PM > SIM 1 status: pin required INFO : 9/23/2019 3:45:36 PM > Codename: dreamqltesq INFO : 9/23/2019 3:45:36 PM > Connecting to modem port... INFO : 9/23/2019 3:45:40 PM > Found phone on COM40 INFO : 9/23/2019 3:45:40 PM > Reading IMEI... INFO : 9/23/2019 3:45:46 PM > OK INFO : 9/23/2019 3:45:46 PM > ----------------------------------------------------------------------------------- WARN : 9/23/2019 3:45:46 PM > Connecting to server... WARN : 9/23/2019 3:45:49 PM > OK INFO : 9/23/2019 3:45:49 PM > Checking smart card... INFO : 9/23/2019 3:46:00 PM > OK INFO : 9/23/2019 3:46:00 PM > Username: mursaleen INFO : 9/23/2019 3:46:00 PM > Authorizing... INFO : 9/23/2019 3:46:03 PM > OK INFO : 9/23/2019 3:46:03 PM > Checking balance... INFO : 9/23/2019 3:46:05 PM > OK INFO : 9/23/2019 3:46:05 PM > Checking operation... INFO : 9/23/2019 3:46:08 PM > OK INFO : 9/23/2019 3:46:08 PM > Your balance: 100 credits. INFO : 9/23/2019 3:46:08 PM > ----------------------------------------------------------------------------------- INFO : 9/23/2019 3:46:08 PM > Sending device information... INFO : 9/23/2019 3:46:10 PM > OK INFO : 9/23/2019 3:46:20 PM > Initializing exploit... INFO : 9/23/2019 3:46:38 PM > OK INFO : 9/23/2019 3:46:38 PM > Checking lock status... WARN : 9/23/2019 3:46:38 PM > Locked INFO : 9/23/2019 3:46:38 PM > Unlocking phone... ERROR : 9/23/2019 3:46:38 PM > Please update phone's firmware and try again! ERROR : 9/23/2019 3:46:39 PM > Phone unlocking failed INFO : 9/23/2019 3:46:40 PM > Performed by 2.8.2.3 Software version. INFO : 9/23/2019 3:47:54 PM > ----------------------------------------------------------------------------------- INFO : 9/23/2019 3:47:56 PM > Platform: Samsung Android INFO : 9/23/2019 3:47:56 PM > Selected port: COM40 INFO : 9/23/2019 3:47:56 PM > Selected model: SM-G950U INFO : 9/23/2019 3:47:56 PM > Operation: Unlock INFO : 9/23/2019 3:48:22 PM > Attention: The Unlock process may take up to 10 minutes, in some cases period of waiting may be extended up to 48 hours! WARN : 9/23/2019 3:48:22 PM > Searching for a phone. Please wait... WARN : 9/23/2019 3:48:22 PM > Please, press "OK" button on the phone to allow USB debugging. ERROR : 9/23/2019 3:48:22 PM > Proper android device not found. Make sure that "USB debug" option on the device is turned on. ERROR : 9/23/2019 3:48:22 PM > Phone unlocking failed INFO : 9/23/2019 3:48:22 PM > Performed by 2.8.2.3 Software version. |
09-23-2019, 12:54 | #12 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
Hello, read the log of the octopus software you have installed the complete combination not the eng modem (combination modem) binary 5 for g950u, you need to install the modem not the complete combination file to unlock the network. Platform: Samsung Android INFO : 9/23/2019 3:45:31 PM > Selected port: COM1 INFO : 9/23/2019 3:45:31 PM > Selected model: SM-G950U INFO : 9/23/2019 3:45:31 PM > Operation: Unlock WARN : 9/23/2019 3:45:31 PM > Searching for a phone. Please wait... WARN : 9/23/2019 3:45:34 PM > Please, press "OK" button on the phone to allow USB debugging. INFO : 9/23/2019 3:45:35 PM > Detected phone model: SM-G950U INFO : 9/23/2019 3:45:35 PM > Firmware compiled date: Wed Jul 4 11:26:54 KST 2018 INFO : 9/23/2019 3:45:35 PM > PDA version: FA70_G950USQU5ARG4 INFO : 9/23/2019 3:45:35 PM > CSC version: unknown INFO : 9/23/2019 3:45:35 PM > SW version: G950USQU5CRF1 INFO : 9/23/2019 3:45:36 PM > Phone SN: R28J51P9T2W INFO : 9/23/2019 3:45:36 PM > Android version: 7.0 (NRD90M) INFO : 9/23/2019 3:45:36 PM > Sales code: unknown INFO : 9/23/2019 3:45:36 PM > Country: unknown INFO : 9/23/2019 3:45:36 PM > HW platform: msm8998 INFO : 9/23/2019 3:45:36 PM > HW Chip: MSM8998 INFO : 9/23/2019 3:45:36 PM > HW Modem: MSM8998 INFO : 9/23/2019 3:45:36 PM > Security patch level: 2017-02-01 INFO : 9/23/2019 3:45:36 PM > Warranty Void: 0 INFO : 9/23/2019 3:45:36 PM > SIM 1 status: pin required INFO : 9/23/2019 3:45:36 PM > Codename: dreamqltesq Also octopus team in the previous post wrote to you to install the combination modem: Please, try to write modem from this G950USQU5ARG4 combination firmware, follow: ""SAMSUNG/COMBINATION/SM-G950U" folder after post here full Software log of Unlock operation At this link you will find the combination binary 5 modem for g950u G950USQU5ARG4_ENG_modem_U5 Download: https://boxwares.net/f3b44580fcfe203...es.tar_(2).md5 | |
