g955u drk fix bit 7 plrase help [Answered] i badly need to repair drk of g955u tmb with bit7. i flash with combination than write officila rom. but still same problem.. please help. |
G955U_U7_Android_9.0_FIX_DRK_-_dm-verity_Failed_Frp_ON_RMM_ON.tar/file G955U U7 Android 9.0 FIX DRK - dm-verity Failed Frp ON RMM ON For the binary 7 firmware for g955u you need to download what you have installed on the phone whether it is a brand or a non-brand operator to extract the img file system and rename it in tar format https://samfrew.com/it/download/Gala...G955UOYN7DSL3/ Firmware and Extract by 7z or WinRAR. 2-When extracting files, rename the file AP_G955U Then delete the extension .md5 3-Open AP File then Extract the system file. 4-Now create an archive of the system file that we extracted previously by a program 7z. 5-Choose the file format .tar Then, create the file. 6-Download Fix Drk file. 7-Now we have two files (DRK File,SYSTEM.tar File). 8-Boot your phone to Download Mode(press Volume Down + Bixby + Power button). 9-Open Odin Tool and wait to get a blue sign in Odin. 10-Add the DRK File to BL. 11-Do NOT tick any extra boxes. 12-Click the start button, wait for Odin to say 'PASS'. 13-Boot your phone to Download Mode again. 14-From odin tool Add the SYSTEM File to AP. 15-Click the start button, wait for Odin to say 'PASS'. 16-Then the device will work without problems. In case you have g955u with frp: off 8 not active and rmm: off or kg state:Off not active, you can try with the root to restart the phone, in case the g955u model allows you to root having blocked bootloaders and snapdragon processor, in case you have to use the guide above. If by any chance the method is unsuccessful, unfortunately there is no solution at the moment to repair drk to g955u firmware binary 7 |
