10-10-2012, 09:33 | #1 (permalink) |
Insane Poster Join Date: Apr 2005 Location: Budapest, Hungary Age: 46
Member: 136872 Status: Offline Thanks Meter: 7 | Galaxy ACE 2 I8160 unlock fail Code: Welcome to Octopus Box Samsung software version 1.6.3 ----------------------------------------------------------------------------------- To connect GT-I8160 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "Modem" value. 8. Restart phone. 9. Press "Read Info" in Octopus Samsung software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: GT-I8160 Searching for a phone. Please wait... Phone found. Firmware compiled date: Tue Apr 24 05:20:57 KST 2012 Android version: 2.3.6 (GINGERBREAD) Selected firmware file: I8160_Ready_to_root.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I8160 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing Kernel section... Kernel section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: GT-I8160 Searching for a phone. Please wait... Phone found. Firmware compiled date: Tue Apr 24 05:20:57 KST 2012 Android version: 2.3.6 (GINGERBREAD) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: GT-I8160 Searching for a phone. Please wait... Phone found. Firmware compiled date: Tue Apr 24 05:20:57 KST 2012 Android version: 2.3.6 (GINGERBREAD) Unlocking phone... Reading data from phone... Data read successfully. Please conect phone to BOX via UART cable. Searching for a phone. Please wait... Phone found. Unlocking phone. It can take some time. Please wait... Please insert card into phone, if phone is locked, then type 00000000 Phone is successfully unlocked |
10-10-2012, 09:40 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please make Factory reset. Also please upload somewhere "*.logx" file of Unlock procedure from "c:\Program Files\GsmServer\OctopusSamsung\LOG\" and post here link. We will look where is the problem with your phone. |
11-10-2012, 11:40 | #5 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Hungary Age: 47
Member: 3097 Status: Offline Thanks Meter: 30 | Hi! I have same problem here, after sucsessfully rooting, and unlocking phone still needs NCK, and can't accept 00000000 log and logx attached here: https://dl.dropbox.com/u/78379419/LOGx.rar Any help would be nice, thx Mobileman_hu |
11-11-2012, 10:51 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please try to make Unlock again, then make Factory reset and then check if the phone unlocked successfully. |
02-23-2013, 20:52 | #7 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Panama, Panama
Member: 1229408 Status: Offline Sonork: 100.1603133 Thanks Meter: 1,917 | Bienvenido en Octopus Box Samsung software versión 1.8.0 ----------------------------------------------------------------------------------- To connect GT-S5830L phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I8160L phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "Modem" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: GT-I8160L Searching for a phone. Please wait... ADB server killed. Phone found. Fecha de creación del firmware: Thu Nov 15 19:46:53 KST 2012 Android version: 2.3.6 (GINGERBREAD) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: GT-I8160L Searching for a phone. Please wait... Phone found. Fecha de creación del firmware: Thu Nov 15 19:46:53 KST 2012 Android version: 2.3.6 (GINGERBREAD) Liberando el teléfono... Reading data from phone... Can't root Android version 2.3.6 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. La liberación del teléfono ha sido fallada Seleccione el archivo de firmware: I8160_Ready_to_root.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I8160L phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on El archivo fue creado para otro modelo de teléfono ----------------------------------------------------------------------------------- To connect GT-I8160 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "Modem" value. 8. Restart phone. 9. Press "Read Info" in software. Please switch your phone to the download mode and connect it to a PC. To put GT-I8160 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing Firmware Failed Please switch your phone to the download mode and connect it to a PC. To put GT-I8160 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Escribiendo la sección Kernel... L a sección Kernel ha sido escrita con éxito La escritura del firmware ha sido completada con éxito ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: GT-I8160 Searching for a phone. Please wait... Phone found. Fecha de creación del firmware: Thu Nov 15 19:46:53 KST 2012 Android version: 2.3.6 (GINGERBREAD) Liberando el teléfono... Reading data from phone... Can't root Android version 2.3.6 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. La liberación del teléfono ha sido fallada ----------------------------------------------------------------------------------- To connect GT-I8160L phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "Modem" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: GT-I8160L Searching for a phone. Please wait... Phone found. Fecha de creación del firmware: Thu Nov 15 19:46:53 KST 2012 Android version: 2.3.6 (GINGERBREAD) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: GT-I8160L Searching for a phone. Please wait... Phone found. Fecha de creación del firmware: Thu Nov 15 19:46:53 KST 2012 Android version: 2.3.6 (GINGERBREAD) Liberando el teléfono... Reading data from phone... Can't root Android version 2.3.6 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. La liberación del teléfono ha sido fallada ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: GT-I8160L Searching for a phone. Please wait... Phone found. Fecha de creación del firmware: Thu Nov 15 19:46:53 KST 2012 Android version: 2.3.6 (GINGERBREAD) Liberando el teléfono... Reading data from phone... Can't root Android version 2.3.6 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. La liberación del teléfono ha sido fallada Seleccione el archivo de firmware: I8160LUBLH1_I8160LUUBLH1 _I8160LUBLH1_HOME.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I8160L phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Inválido formato del archivo Seleccione el archivo de firmware: I8160LUBLH1_I8160LUUBLH1 _I8160LUBLH1_HOME.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I8160L phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing Firmware Failed Please switch your phone to the download mode and connect it to a PC. To put GT-I8160L phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Escribiendo la sección PWR MGT... L a sección PWR MGT ha sido escrita con éxito Escribiendo la sección Kernel... L a sección Kernel ha sido escrita con éxito Escribiendo la sección Modem... L a sección Modem ha sido escrita con éxito Escribiendo la sección SYSTEM... L a sección SYSTEM ha sido escrita con éxito Escribiendo la sección CACHEFS... L a sección CACHEFS ha sido escrita con éxito Escribiendo la sección HIDDEN... L a sección HIDDEN ha sido escrita con éxito La escritura del firmware ha sido completada con éxito ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: GT-I8160L Searching for a phone. Please wait... ADB server killed. Phone found. Fecha de creación del firmware: Mon Aug 6 18:53:11 KST 2012 Android version: 2.3.6 (GINGERBREAD) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: GT-I8160L Searching for a phone. Please wait... Phone found. Fecha de creación del firmware: Mon Aug 6 18:53:11 KST 2012 Android version: 2.3.6 (GINGERBREAD) Liberando el teléfono... Reading data from phone... Can't root Android version 2.3.6 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. La liberación del teléfono ha sido fallada Seleccione el archivo de firmware: I8160_Ready_to_root.oct ----------------------------------------------------------------------------------- To connect GT-I8160 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "Modem" value. 8. Restart phone. 9. Press "Read Info" in software. Please switch your phone to the download mode and connect it to a PC. To put GT-I8160 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Escribiendo la sección Kernel... L a sección Kernel ha sido escrita con éxito La escritura del firmware ha sido completada con éxito ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: GT-I8160 Searching for a phone. Please wait... Phone found. Fecha de creación del firmware: Mon Aug 6 18:53:11 KST 2012 Android version: 2.3.6 (GINGERBREAD) Liberando el teléfono... Reading data from phone... Can't root Android version 2.3.6 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. La liberación del teléfono ha sido fallada I cant unlock it, its already rooted. |
02-25-2013, 07:10 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. As we can see - your phone is not rooted: Quote:
