04-01-2015, 12:38 | #1 (permalink) |
Freak Poster Join Date: Nov 2014 Location: argentina
Member: 2298273 Status: Offline Thanks Meter: 9 | the galaxy i8550L is properly supported? [Solved] Bienvenido en Octoplus/Octopus Box Samsung software versión 1.9.0 ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM54 Modelo seleccionado: GT-I8550L Reading info, please wait... ADB server killed. Modelo del teléfono detectado: GT-I8550L Fecha de creación del firmware: Sat Nov 16 03:18:24 KST 2013 PDA version: I8550LUBUAMK1 CSC version: I8550LUUBAMK1 Versión del SW: I8550LUBUAMK1 IMEI del teléfono: 357570051288190 Phone SN: RV1F51E5P5W Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM54 Modelo seleccionado: GT-I8550L Modo: Emergencia Write IMEI failed previously had a firmware CLARO but gives the same result with the ARO firmware I put Last edited by Octopus box; 04-02-2015 at 06:07. |
04-01-2015, 12:48 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. "Modo: Emergencia" means, that You have not configured the phone correctly. Please look here (http://forum.gsmhosting.com/vbb/f684.../#post10946469), try to do the same and repeat the operation again. Try to select COM port manually. Post here the result. |
04-01-2015, 13:15 | #3 (permalink) | |
Member: 2298273 Status: Offline Thanks Meter: 9 | Quote:
----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM4 Modelo seleccionado: GT-I8550L Reading info, please wait... Modelo del teléfono detectado: GT-I8550L Fecha de creación del firmware: Sat Nov 16 03:18:24 KST 2013 PDA version: I8550LUBUAMK1 CSC version: I8550LUUBAMK1 Versión del SW: I8550LUBUAMK1 IMEI del teléfono: 357570051288190 Phone SN: RV1F51E5P5W Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM4 Modelo seleccionado: GT-I8550L Modo: Emergencia Write IMEI failed not work also set with *#9090# I try everything they said , manually select the port , set the cellular phone restart , and does not work ! | |
04-01-2015, 13:18 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Do the next: 1. Disconnect all other devices from your PC. 2. Connect the phone directly to PC motherboard USB port. 3. Install the latest drivers (http://octoplusbox.com/files/drivers...ile_Phones.exe). 4. Re-start the phone. 5. Configure the phone again: 5.1. Disconnect USB cable from phone. 5.2. Go to Menu->Settings->More->About Device. 5.3. Tap on "Build number" 7 times to enable developer options. 5.4. Go to Menu->Settings->More->Developer options. 5.5. Turn on "USB Debugging" option. 5.6. Go to dial window. 5.7. Enter "*#0808#" number. 5.8. Select "DM+Modem+ADB". 5.9. Press Home button. 6. Make Unlock. |
04-01-2015, 13:47 | #5 (permalink) | |
Bienvenido en Octoplus/Octopus Box Samsung software versión 1.9.0 ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM3 Modelo seleccionado: GT-I8550L Reading info, please wait... Modelo del teléfono detectado: GT-I8550L Fecha de creación del firmware: Sat Nov 16 03:18:24 KST 2013 PDA version: I8550LUBUAMK1 CSC version: I8550LUUBAMK1 Versión del SW: I8550LUBUAMK1 IMEI del teléfono: 357570051288190 Phone SN: RV1F51E5P5W Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM3 Modelo seleccionado: GT-I8550L Modo: Normal Modelo del teléfono: QSOSKOLY El modelo del teléfono no está soportado ¡En el puerto seleccionado el teléfono no fue detectado! Intentando a buscar el puerto USB diagnóstico... Intentando a conectar el teléfono en COM5 Modo: Emergencia Write IMEI failed __________________________________________________ _____________________________________________ Bienvenido en Octoplus/Octopus Box Samsung software versión 1.9.0 ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM5 Modelo seleccionado: GT-I8550L Reading info, please wait... Modelo del teléfono detectado: GT-I8550L Fecha de creación del firmware: Sat Nov 16 03:18:24 KST 2013 PDA version: I8550LUBUAMK1 CSC version: I8550LUUBAMK1 Versión del SW: I8550LUBUAMK1 IMEI del teléfono: 357570051288190 Phone SN: RV1F51E5P5W Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM5 Modelo seleccionado: GT-I8550L Modo: Emergencia Write IMEI failed __________________________________________________ _______________________________________ same with unlock | |
04-01-2015, 13:50 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Contact us right now to Skype, Yahoo! Messenger or ICQ, we will look remotely, where can be the problem with your device. Our contacts You can find in our profile. |
04-01-2015, 14:29 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Run this Support Client (http://octoplusbox.com/files/softs/O...ort_client.exe) and send us ID and Pass to PM. |
