03-02-2017, 11:00 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Galaxy j5 prime g570f need help to find COMBINATION FIRMWARE Please I have G570F need to remove FRP SN: R28H92Q3MLW recovry mode info: Code: Android Recovery MMB29K.G570FXXU1API4 samsung/on5xeltejv/on5xelte 6.0.1/MMB29K/G570FXXU1API4 Thanks in advance |
03-02-2017, 11:37 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Currently we have only "COMBINATION_OJV_FA60_G570FXXU1API2_OJV1API2_CL921 8515_QB10877448" Combination firmware for SM-G570F. The file is available in "samsung/Combination" folder of the Support Area. To access Support Area, press "Go to support" button on "Support & options" tab of the Software. Also You can use Files Downloader on "Support & options" tab of the Software to browse, search and download files from the Support Area. |
03-02-2017, 12:24 | #3 (permalink) |
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Thanks for quick reply its good to ask than do anything no sens so is it safe to flash with any latest firmware Thanks in advance |
03-02-2017, 12:34 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Writing of Combination firmware is safe, but it might be not compatible with phone's firmware. In such case You'll need to reflash the phone with an original firmware. |
03-03-2017, 10:59 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please post here full Software log of performed operations. Quote:
03-03-2017, 13:18 | #9 (permalink) | |
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Quote:
now I have reflashed it with original firmware Code: Welcome to Octoplus/Octopus Box Samsung software version 2.4.8 ----------------------------------------------------------------------------------- To connect SM-G570F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected BOOT file: G:\samsung\G570FXXU1AQA2_ODD1APL6_India_ 6.0.1\BL_G570FXXU1AQA2_CL10285063_QB12142979_REV00 _user_low_ship.tar.md5 Selected AP file: G:\samsung\G570FXXU1AQA2_ODD1APL6_India_ 6.0.1\AP_G570FXXU1AQA2_CL10285063_QB12142979_REV00 _user_low_ship.tar.md5 Selected CP file: G:\samsung\G570FXXU1AQA2_ODD1APL6_India_ 6.0.1\CP_G570FXXU1APL1_CL9645622_QB11899985_REV00 _user_low_ship.tar.md5 Selected CSC file: G:\samsung\G570FXXU1AQA2_ODD1APL6_India_ 6.0.1\CSC_ODD_G570FODD1APL6_CL9394113_QB11878540_REV00 _user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G570F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing USERDATA section... USERDATA section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.4.8 Software version. | |
03-03-2017, 13:29 | #10 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
03-03-2017, 13:30 | #11 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 727810 Status: Offline Sonork: 100.1627301 Thanks Meter: 167 | pm me i will help you for frp lock , i have already done frp & stuck with cert write option now |
The Following User Says Thank You to max_cool For This Useful Post: |
