Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 03-10-2014, 19:17   #1 (permalink)
Member: 2138487
Thanks Meter: 4
galaxy S3 i9300 baseband and imei null null
Hello I have a galaxy s3 with unknown baseband I flashed a different firmware and modem firmware 4.1.2 but I can not make it work, is there any solution?
Thank you.
Old 03-10-2014, 19:32   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,405
Hello.
Please make Repair EFS, then Repair IMEI and post here results.
Old 03-12-2014, 10:03   #3 (permalink)
Member: 2138487
Thanks Meter: 4
hello is there any firmware suitable to restore the baseband or how can I fix?
Old 03-12-2014, 10:05   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Try to write different firmwares from the Support Area one by one and check, whether the baseband isn't unknown.
Old 03-12-2014, 18:52   #5 (permalink)
Member: 2138487
Thanks Meter: 4
if cloned "read efs and read the security" of a s3 running and I copy them into my I can solve the problem of the baseband?
Old 03-13-2014, 07:54   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
No, most likely, this will not help to solve the problem, because Security and EFS is HW depended. But You can try, of course. The best way is to write different firmwares and check whether the baseband isn't unknown. If after of writing of all available firmwares, baseband is still unknown, most likely, this is phone's HW problem.
Old 03-13-2014, 13:55   #7 (permalink)
Member: 108017
Thanks Meter: 6
Originally Posted by Octopus box View Post
Hello.
Plus Repair S/N - 100% working!
WBR,
vladimik
Old 03-13-2014, 14:51   #8 (permalink)
Member: 2138487
Thanks Meter: 4
hello what it means to Repair Plus S / N - 100% working! ? I have to repair the S / N to restore baseband?
Old 03-13-2014, 14:55   #9 (permalink)
Member: 510470
Thanks Meter: 42
What is the situation I Done
Old 03-13-2014, 15:02   #10 (permalink)
Member: 2138487
Thanks Meter: 4
imei and baseband unknown null null if I write firmware 4.3 with ocotpus writing fails in hidden partition
Old 03-13-2014, 15:06   #11 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
IMEI is OK and legal, but SN = 00000000000. That means no network and no phone calls.
before all else the phones efs fıle had been broken .ıt reads from efs memblock. when ıt done patch operatıon code of network past to modem.when you update your network will be gone.
what can we do on thıs case ?
Patch download application and install on your phone after click apply patch or If you have internet wait for orientation the patch online..And apply patch
http://www.arizandroid.com/patch/ARIZAPatch.apk
Old 03-17-2014, 21:20   #12 (permalink)
Member: 2138487
Thanks Meter: 4
how can I write the phone over to change modem firmware or anything but I also tried arizapatch ,with the deep clean there is the possibility to rewrite the modem?
Old 03-18-2014, 05:59   #13 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
Brother there is two types of problem with unknown baseband.
1. Software & 2. Hardware
If software problem is there must flash the phone for recovery baseband.
After the flash phone if same unknown baseband this is 100% hardware problem.
2. For the hardware repair must be replace EMMC IC.
BR.
Siddeque
Old 03-18-2014, 06:19   #14 (permalink)
Member: 1643629
Sonork: bhupal_regmi2002
Thanks Meter: 2
80% hardware (try to repair may help u)
Old 03-20-2014, 06:13   #15 (permalink)
Member: 108017
Thanks Meter: 6
After Repair EFS - S/N = 00000000000, you need repair it (written on label under IMEI) after repear IMEI.
WBR
Page generated in 0.20164 seconds with 8 queries
