11-01-2012, 12:05 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: UK. Worcester Age: 35
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | Galaxy S3 i9300 no power menu, no lock screen after EFS repair [Solved] LOG from EFS repair: INFO : 31/10/2012 19:09:19 > Platform: Samsung Android INFO : 31/10/2012 19:09:19 > Selected port: COM14 INFO : 31/10/2012 19:09:19 > Selected model: GT-I9300 WARN : 31/10/2012 19:09:19 > To put GT-I9300 phone into download mode you have to perform the following steps: WARN : 31/10/2012 19:09:19 > 1. Reconnect phone battery. WARN : 31/10/2012 19:09:19 > 2. Press and hold "Volume - " + "Home" + "Power" buttons. WARN : 31/10/2012 19:09:19 > 3. When phone turns on press "Volume+" button. INFO : 31/10/2012 19:09:27 > Repairing EFS... INFO : 31/10/2012 19:09:27 > Searching for a phone. Please wait... INFO : 31/10/2012 19:09:27 > Phone found. INFO : 31/10/2012 19:09:28 > EFS Repair successfully Log file "C:\Program Files\GsmServer\OctopusSamsung\LOG\31-10-2012_18-57-24.log" closed (31/10/2012 19:12:47). LOG from IMEI repair: INFO : 31/10/2012 19:22:45 > Platform: Samsung Android INFO : 31/10/2012 19:22:45 > Selected port: COM14 INFO : 31/10/2012 19:22:45 > Selected model: GT-I9300 INFO : 31/10/2012 19:22:45 > Searching for a phone. Please wait... INFO : 31/10/2012 19:22:45 > Phone found. INFO : 31/10/2012 19:22:45 > Firmware compiled date: Thu Jul 26 12:15:02 KST 2012 INFO : 31/10/2012 19:22:46 > Phone SN: 00000000000 INFO : 31/10/2012 19:22:46 > Android version: 4.0.4 (IMM76D) INFO : 31/10/2012 19:22:46 > Old IMEI: Unknown INFO : 31/10/2012 19:22:46 > New IMEI: 353922-05-******-* INFO : 31/10/2012 19:22:48 > Erasing old IMEI. It can take some time. Please wait... INFO : 31/10/2012 19:22:51 > Creating NVM backup INFO : 31/10/2012 19:22:51 > Backup saved as C:\Program Files\GsmServer\OctopusSamsung\BACKUP\NVDATA-GT-I9300-31-10-2012_19-22-51-.nvm file INFO : 31/10/2012 19:22:59 > Old IMEI was erased successfully. WARN : 31/10/2012 19:22:59 > Phone will restart now WARN : 31/10/2012 19:23:48 > After phone being rebooted and powered on perform the following steps: WARN : 31/10/2012 19:23:48 > 1. Disconnect USB cable. WARN : 31/10/2012 19:23:48 > 2. Go to dial window. WARN : 31/10/2012 19:23:48 > 3. Enter *#9090# number. WARN : 31/10/2012 19:23:48 > 4. Set speed to 115200. WARN : 31/10/2012 19:23:48 > 5. Connect phone via UART cable to Box. INFO : 31/10/2012 19:23:49 > Connecting to phone, please wait... INFO : 31/10/2012 19:24:09 > Phone connected successfully INFO : 31/10/2012 19:24:09 > Deactivating MSL... INFO : 31/10/2012 19:24:38 > MSL deactivate successfully INFO : 31/10/2012 19:25:35 > Writing new phone IMEI... INFO : 31/10/2012 19:25:36 > New IMEI successfully written. INFO : 31/10/2012 19:25:36 > Please, restart the phone to apply changes INFO : 31/10/2012 19:26:42 > Also i see that SN is corupted so here is log from SN repair: INFO : 31/10/2012 19:26:42 > Platform: Samsung Android INFO : 31/10/2012 19:26:42 > Selected port: COM14 INFO : 31/10/2012 19:26:42 > Selected model: GT-I9300 INFO : 31/10/2012 19:26:43 > Searching for a phone. Please wait... INFO : 31/10/2012 19:26:45 > Phone found. INFO : 31/10/2012 19:26:45 > Firmware compiled date: Thu Jul 26 12:15:02 KST 2012 INFO : 31/10/2012 19:26:46 > Phone SN: 00000000000 INFO : 31/10/2012 19:26:46 > Android version: 4.0.4 (IMM76D) INFO : 31/10/2012 19:26:48 > Repairing Serial Number. It can take some time. Please wait... WARN : 31/10/2012 19:26:59 > Phone will restart now INFO : 31/10/2012 19:27:00 > SN repaired successfully. INFO : 31/10/2012 19:28:08 > ----------------------------------------------------------------------------------- INFO : 31/10/2012 19:28:08 > Platform: Samsung Android INFO : 31/10/2012 19:28:08 > Selected port: COM14 INFO : 31/10/2012 19:28:09 > Selected model: GT-I9300 INFO : 31/10/2012 19:28:09 > Searching for a phone. Please wait... INFO : 31/10/2012 19:28:09 > Phone found. INFO : 31/10/2012 19:28:09 > Firmware compiled date: Thu Jul 26 12:15:02 KST 2012 INFO : 31/10/2012 19:28:10 > Phone SN: X6YAF000000 INFO : 31/10/2012 19:28:10 > Android version: 4.0.4 (IMM76D) INFO : 31/10/2012 19:28:12 > Repairing Serial Number. It can take some time. Please wait... WARN : 31/10/2012 19:28:23 > Phone will restart now INFO : 31/10/2012 19:28:23 > SN repaired successfully. Log file "C:\Program Files\GsmServer\OctopusSamsung\LOG\31-10-2012_19-21-34.log" closed (31/10/2012 19:29:41). Also SN is not repaired as it should be. Please try to solve my problem OCTOPUS team. EFS repair and SN repair is not good at the moment... This is second i9300 with same problem. THanks Last edited by Octopus box; 10-21-2013 at 06:09. |
11-01-2012, 12:37 | #2 (permalink) | ||
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello easy to fix posted by me in other section. root your phone. and use this commands FOR I9300 only Quote:
Regards, Chevli Last edited by stanner_austin; 11-01-2012 at 15:07. Reason: update and correction worked for user. | ||
11-01-2012, 13:16 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please at first make Factory reset, then make Repair IMEI and only then make Repair SN. Write the result here. |
11-01-2012, 13:42 | #5 (permalink) | |
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | Quote:
Here is LOG: Welcome to Octopus Box Samsung software version 1.6.6 ----------------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in Octopus Samsung software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: GT-I9300 Searching for a phone. Please wait... ADB server killed. Phone found. Firmware compiled date: Thu Jul 26 12:15:02 KST 2012 Phone SN: X6YAF000000 Android version: 4.0.4 (IMM76D) Old IMEI: Unknown New IMEI: 353922-05-111622-4 Erasing old IMEI. It can take some time. Please wait... Creating NVM backup Backup saved as C:\Program Files\GsmServer\OctopusSamsung \BACKUP\NVDATA-GT-I9300-01-11-2012_12-37-12-.nvm file Old IMEI was erased successfully. Phone will restart now After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Go to dial window. 3. Enter *#9090# number. 4. Set speed to 115200. 5. Connect phone via UART cable to Box. Connecting to phone, please wait... Phone connected successfully Deactivating MSL... MSL deactivate successfully Writing new phone IMEI... New IMEI successfully written. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: GT-I9300 Searching for a phone. Please wait... Phone found. Firmware compiled date: Thu Jul 26 12:15:02 KST 2012 Phone SN: 00000000000 Android version: 4.0.4 (IMM76D) Repairing Serial Number. It can take some time. Please wait... Phone will restart now SN repaired successfully. | |
11-01-2012, 14:31 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please contact us tomorrow, we will give You new test software version. |
11-01-2012, 15:22 | #7 (permalink) |
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | All sorted now. Many thanks to stanner_austin who helped me via teamviewer big time. Serial number is still wrong but thats ok. Power menu is there now, and lockscreen as well... .....but i will contact u octopus anyway. |
11-02-2012, 09:15 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please check your PM, we have sent You new test version. Please try to make Repair SN with this version and post here the result. |
11-02-2012, 12:18 | #10 (permalink) | |
LOG: Welcome to Octopus Box Samsung software version 1.6.7 ----------------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in Octopus Samsung software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: GT-I9300 Searching for a phone. Please wait... Phone found. Firmware compiled date: Fri Oct 19 18:22:47 KST 2012 Phone SN: X6YAF000000 Android version: 4.1.1 (JRO03C) Repairing Serial Number. It can take some time. Please wait... Repair SN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: GT-I9300 Searching for a phone. Please wait... Phone found. Firmware compiled date: Fri Oct 19 18:22:47 KST 2012 Phone SN: X6YAF000000 Android version: 4.1.1 (JRO03C) Repairing Serial Number. It can take some time. Please wait... Repair SN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: GT-I9300 Searching for a phone. Please wait... Phone found. Firmware compiled date: Fri Oct 19 18:22:47 KST 2012 Phone SN: X6YAF000000 Android version: 4.1.1 (JRO03C) Repairing Serial Number. It can take some time. Please wait... Repair SN failed | |
11-02-2012, 13:07 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please use the latest test software version we have sent You to your PM. |
11-02-2012, 13:47 | #12 (permalink) | |
LOG: Welcome to Octopus Box Samsung software version 1.6.7 ----------------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in Octopus Samsung software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: GT-I9300 Searching for a phone. Please wait... Phone found. Firmware compiled date: Fri Oct 19 18:22:47 KST 2012 Phone SN: X6YAF000000 Android version: 4.1.1 (JRO03C) Repairing Serial Number. It can take some time. Please wait... Phone will restart now SN repaired successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: GT-I9300 Searching for a phone. Please wait... Phone found. Firmware compiled date: Fri Oct 19 18:22:47 KST 2012 Phone SN: RV1C80X6YAF Android version: 4.1.1 (JRO03C) Thank u octopus. Hope u will release it soon. And please do something about EFS repair as well...Coz everytime u do EFS repair, phone is without power menu and lockscreen and also stuck in factorymode i think. Thanks again. | |
The Following 2 Users Say Thank You to Thorenzz For This Useful Post: |
