07-11-2014, 11:25 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: ivory coast
Member: 801805 Status: Offline Sonork: 1618365 Thanks Meter: 24 | Galaxy s4 i337 att flash done but system kernel fail give another solution |
07-11-2014, 14:08 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Most likely, there was KNOX enabled in your device or phone has secured boot. You should write the same firmware version, that was in the phone before (when it was working). |
07-11-2014, 14:59 | #3 (permalink) |
Member: 801805 Status: Offline Sonork: 1618365 Thanks Meter: 24 | before flash the phone its I337UCUFNC1 4.4.2 now i need to downgrade to 4.2.2 and the phone is brick it show in download mode: knox kernel lock:0*ffffffffffc knox warranty void:0*ffffffffffc CSB CONFIG-LSB:0*30 write protection enable emmc burst mode enable i will flash with own file |
07-11-2014, 20:27 | #4 (permalink) |
Member: 801805 Status: Offline Sonork: 1618365 Thanks Meter: 24 | i search in google and i get on xda site this stock rom I337UCUFNC1_100%_Stock_Rooted_ROM it flash by copy all file in sd card but my phone no go in recovery mode ,help |
07-12-2014, 00:29 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Albania,City Under The Castle Age: 47
Member: 388033 Status: Offline Thanks Meter: 693 | once you downgraded the phone you can not return to the lower version even it was working before but now the only way to solve is by flashing the latest version with odin ,i fixed 1 M919 this way |
07-12-2014, 07:40 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Install the latest Software version (Software), disable KNOX, root the phone and perform the Repair IMEI operation. Then post here full Software log. Also, look here: http://forum.gsmhosting.com/vbb/f684...olved-1836176/. |
