08-11-2013, 03:21 | #1 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Mexico
Member: 527046 Status: Offline Thanks Meter: 97 | Galaxy S4 i337M cann´t repair imei i´ve changed firmware version and i got same results. here is repair procedure with octopus: Quote:
octopus box shows the repair procedure as successfully. but there´s no changes inside phone. it has old imei. the original carrier is Telcel Mexico. can you tell me how can i solve it please. thanks | |
08-12-2013, 11:13 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Octopus/Octoplus Box Samsung Software currently supports only Fast IMEI Repair method for this phone model. If You have read carefully software release news, this method works only for phones with non-damaged (not changed) file system (http://forum.gsmhosting.com/vbb/9583877-post24.html): Quote:
Please contact us, we will prepare test software version for You that performs general Repair IMEI procedure. Our contacts You can find in our profile. | |
11-01-2013, 20:36 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Standard Repair IMEI method for this model was added in last update. It also supports phones with new security. Please try out latest software version and post results here. |
12-13-2013, 19:03 | #5 (permalink) | |
Junior Member Join Date: Nov 2013
Member: 2065663 Status: Offline Thanks Meter: 0 | Quote:
Puerto seleccionado: COM18 Modelo seleccionado: SGH-I337M Modo: Normal Modelo del teléfono: SGH-I337M Fecha de creación del firmware: Mar 28 2013 Tiempo de compilación del firmware: 09:00:00 Fecha de salida del firmware: Apr 23 2013 Tiempo de salida del firmware: 12:36:28 Versión del SW: M9615A-CEFWTAZM-4.0.17062 IMEI antiguo: 004400-15-202000-0 IMEI nuevo: 004400-15-202016-8 Realizando el backup de NVM ¡La lectura de NVM está terminada! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\NVM-SGH-I337M-004400152020000-13-12-2013_09-38-59-.nvm file Fecha de creación del firmware: Tue Apr 23 11:25:26 KST 2013 Phone SN: RF1D478W82J Android version: 4.2.2 (JDQ39) Cheking Root Phone is Rooted Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Fecha de creación del firmware: Mar 28 2013 Tiempo de compilación del firmware: 09:00:00 Fecha de salida del firmware: Apr 23 2013 Tiempo de salida del firmware: 12:36:28 Versión del SW: M9615A-CEFWTAZM-4.0.17062 Found phone on COM18 Reparando el NVM para el teléfono SGH-I337M... New IMEI successfully written. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) I have the same problem and nothing it seas succefuly and after i reapir the NVM and nothing no signal! | |
12-13-2013, 19:31 | #7 (permalink) | |
Puerto seleccionado: COM15 Modelo seleccionado: SGH-I337M Modo: Normal Modelo del teléfono: SGH-I337M Fecha de creación del firmware: Tiempo de compilación del firmware: Fecha de salida del firmware: -ù~ Tiempo de salida del firmware: Versión del SW: IMEI antiguo: Desconocido IMEI nuevo: 356466-05-061126-1 Realizando el backup de NVM ¡La lectura de NVM está terminada! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\NVM-SGH-I337M-13-12-2013_10-23-01-.nvm file Fecha de creación del firmware: Tue Apr 23 11:25:26 KST 2013 Phone SN: RF1D478W82J Android version: 4.2.2 (JDQ39) Cheking Root Phone is Rooted Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Fecha de creación del firmware: Mar 28 2013 Tiempo de compilación del firmware: 09:00:00 Fecha de salida del firmware: Apr 23 2013 Tiempo de salida del firmware: 12:36:28 Versión del SW: M9615A-CEFWTAZM-4.0.17062 Found phone on COM18 Reparando el NVM para el teléfono SGH-I337M... New IMEI successfully written. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM18 Modelo seleccionado: SGH-I337M Modo: Normal Modelo del teléfono: SGH-I337M Fecha de creación del firmware: Mar 28 2013 Tiempo de compilación del firmware: 09:00:00 Fecha de salida del firmware: Apr 23 2013 Tiempo de salida del firmware: 12:36:28 IMEI del teléfono: 356466-05-061126-1 Versión del SW: M9615A-CEFWTAZM-4.0.17062 Realizando el backup de NVM ¡La lectura de NVM está terminada! Reparando el NVM para el teléfono SGH-I337M... La reparación de NVM ha sido terminada con éxito Para aplicar los cambios, reinicie el teléfono Still nothing | |
12-13-2013, 19:46 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try re-flash the phone and then make Repair NVM, don't perform Repair MEI operation. If the problem still will be the same (network is not active) - most likely, this device has another (new) security type, like in new SM-N900a/w8 and currently no solution for such problem. |
