02-26-2014, 04:38 | #1 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2129928 Status: Offline Thanks Meter: 0 | Galaxy S4 M919 4.2.2 fail to unlock [Solved] Platform: Samsung Android Selected port: COM1 Selected model: SGH-M919 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM8 Mode: Emergency the box always says phone in Emergency mode but its not, can't read the phone even USB debugging turned ON, and i already did *#0808# and *#9090#. Please HELP Last edited by Octopus box; 04-23-2014 at 06:48. |
02-26-2014, 07:56 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | You not connect the device correctly. At first, try to connect the device via Micro USB cable. If the device not connect via this cable, try to select correct (box) COM port and connect it via Samsung Micro UART C3300k/C3303k cable. To connect SGH-M919 Micro USB cable, you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. If all of these steps were performed successfully, several new devices should appear in PC Device Manager. |
04-22-2014, 18:57 | #3 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | I just try to unlock a M919 on 4.4.2, rooted with CF Root, but at the end it failed and now IMEI is damaged. Will post the logs tomorrow. Is really M919 4.4.2 can't be unlocked? br, s1emens |
04-23-2014, 04:09 | #4 (permalink) |
Member: 40602 Status: Offline Thanks Meter: 118 | Ty to flash modem file and then repair imei: Welcome to Octoplus/Octopus Box Samsung software version 1.5.4 ----------------------------------------------------------------------------------- To connect GT-I9100G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-M919 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: SGH-M919_modem_CWM_UVUAMDL.oct Please switch your phone to the download mode and connect it to a PC. To put SGH-M919 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing MDM section... MDM section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: SGH-M919 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM49 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 26 2013 Firmware released time: 18:24:03 Incorrect IMEI SW version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM49 Selected model: SGH-M919 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 26 2013 Firmware released time: 18:24:03 Incorrect IMEI SW version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM49 Selected model: SGH-M919 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 26 2013 Firmware released time: 18:24:03 SW version: M9615A-CEFWTAZM-4.0.17062 Old IMEI: 004400-15-202000-0 New IMEI: 355537-05-521760-0 Creating NVM backup Reading NVM done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\NVM-SGH-M919-004400152020000-23-04-2014_09-50- 09-.nvm file Firmware compiled date: Fri Feb 14 14:44:35 KST 2014 PDA version: M919UVUFNB4 CSC version: M919TMBFNB4 SW version: M919UVUAMDL Phone IMEI: Unknown Phone SN: RV1D60QQJ0T Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 26 2013 Firmware released time: 18:24:03 SW version: M9615A-CEFWTAZM-4.0.17062 Found phone on COM49 Repairing NVM for SGH-M919 phone... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM49 Selected model: SGH-M919 Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM49 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 26 2013 Firmware released time: 18:24:03 Phone IMEI: 355537-05-521760-0 SW version: M9615A-CEFWTAZM-4.0.17062 Phone is unlocked. But now when i try to use the phone, it seems very slow lagging and when open camera, it showing updating camera firmware and then camera failed. And the phone gets very hot. I will try to download the firmware and reflash the phone br, s1emens |
The Following User Says Thank You to s1emens For This Useful Post: |
