04-10-2014, 12:32 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | GT-C3303I Sending preloader failed [Solved] ----------------------------------------------------------------------------------- To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: C3303iJPKB1_OJPKB4.oct ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-C3303I Selected port: USB Please, press "volume up" and "lock" connect phone to USB without battery. Connecting... Phone found. Chipset version : 0A SCROM version : 33 Sending loaders... Sending preloader failed. Last edited by Octopus box; 04-10-2014 at 13:24. |
04-10-2014, 13:22 | #3 (permalink) |
Member: 1418524 Status: Offline Thanks Meter: 186 | Welcome to Octoplus/Octopus Box Samsung software version 1.5.2.1 Selected firmware file: C3303iDXKB1_OLAKB1.oct ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-C3303I Selected port: USB Please, press "volume up" and "lock" connect phone to USB without battery. Connecting... Phone found. Chipset version : 0A SCROM version : 33 Sending loaders... Sending preloader failed. ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-C3303I Selected port: USB Please, press "volume up" and "lock" connect phone to USB without battery. Connecting... Phone found. Chipset version : 0A SCROM version : 33 Sending loaders... Preloader send successfully Conecting to pipes... Successfully conecte to pipes. Writing firmware... Writing Firmware Writing partition LCDACT ... Erasing block... Block erase successfully. Writing block... Partition LCDACT write successfully. Writing partition MAIN ... Erasing block... Block erase successfully. Writing block... Partition MAIN write successfully. Writing partition DSP ... Erasing block... Block erase successfully. Writing block... Partition DSP write successfully. Writing partition ROOT ... Erasing block... Block erase successfully. Writing block... Partition ROOT write successfully. Writing partition TFS ... Partition TFS write successfully. Writing partition CSC ... Partition CSC write successfully. Firmware Write successfully. ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-C3303I Selected port: COM1 Baud rate: 921600 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Connecting... Connecting canceled. ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-C3303I Selected port: COM3 Baud rate: 921600 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Connecting... Phone in TAT mode. Reading info, please wait... Phone IMEI A: 357------------- SW version: C3303iDXK Bluetooth MAC: CCF9E8591EA8 Phone SN : RV1B913236 Reading codes... Deactivating MSL... MSL deactivate successfully Freeze lock: 62776000 Net lock: 00000000 Sim lock: 00000000 Phone lock: 00000000 Sp lock: 00000000 All Done thank to fast Support |
