01-08-2014, 11:56 | #1 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1970633 Status: Offline Thanks Meter: 15 | GT-E3210 Unlocking problem i can connect it to box i can repair imei; but the box cannot unlock: Welcome to Octoplus/Octopus Box Samsung software version 1.4.4 ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-E3210 Selected port: COM10 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Connecting... Phone in TAT mode. Reading info, please wait... Phone IMEI A: 35708404444367 SW version: E3210NPKE Bluetooth MAC: 9852B19DB1AD Phone SN : S200002635 Reading phone unlock codes. It can take some time, please wait... FREZEE : 00000001 NET LOCK : 00000000 Subset LOCK : 00000000 SP LOCK : 00000000 CP LOCK : 00000000 ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-E3210 Selected port: COM10 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Connecting... Phone in TAT mode. Reading info, please wait... Phone IMEI A: 35708404444367 SW version: E3210NPKE Bluetooth MAC: 9852B19DB1AD Phone SN : S200002635 Unlocking phone... Phone unlocking failed in the first part of log i select read codes (00000000 don't work) in the second part i select unlock and the program say "Phone unlocking failed" i try to insert a blocked sim and i insert the wrong code 3 times but the result is the same please help me |
01-08-2014, 15:40 | #2 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Quote:
01-09-2014, 11:56 | #3 (permalink) | |
Member: 1970633 Status: Offline Thanks Meter: 15 | Quote:
I find a bug in software if nyou patt from qualcomm (i9300) to swift (e3210) the unlock buttom is active 0.0 THE CODE 00000001 DON'T WORK | |
01-09-2014, 12:12 | #4 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
1. Delete all files from folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\", 2. Run the Software. 3. Perform "Read codes" operation once again. 5. Close the Software. 6. Upload somewhere the last created "*.log" and "*.logx" files from folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\", we will research where can be the problem with your phone. | ||
01-09-2014, 13:25 | #5 (permalink) | |
there is the log: LOG - Download - 4shared - Scimmia Banana | |
01-11-2014, 10:36 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have researched logs, which You have uploaded, and haven't found any errors. Software successfully read all unlocking codes which are in the phone. Maybe, there is branded firmware in your phone and the device doesn't accept the unlocking code. Unfortunately, currently Octopus/Octoplus Samsung Software doesn't support Write firmware for this phone model. We will try to add "Write firmware" and "Direct unlock" operations for this device model in one of the future updates. Last edited by Octopus box; 01-11-2014 at 11:43. |
01-11-2014, 11:32 | #8 (permalink) | |
