04-22-2014, 19:22 | #4 (permalink) |
Freak Poster Join Date: Apr 2013 Location: las palmas
Member: 1926663 Status: Offline Thanks Meter: 22 | Bienvenido en Octoplus/Octopus Box Samsung software versión 1.4.1 ----------------------------------------------------------------------------------- To connect SC-01C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9100P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. Seleccione el archivo de firmware: I9100PBVLPE_I9100PAMNLPE_AMN_Android_4.1.2.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9100P phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Escribiendo la sección BOOT... L a sección BOOT ha sido escrita con éxito Writing Firmware Failed |
