12-13-2013, 02:05 | #1 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2083655 Status: Offline Thanks Meter: 1 | GT-I9001 cannot repair IMEI I want to repair a Galaxy S Plus (I9001) but when I connect it on Octopus, say this: Plataforma: Samsung Android Puerto seleccionado: COM4 Modelo seleccionado: GT-I9001 Modo: Normal Modelo del teléfono: GT-I9001 Versión del SW: I9001XXKPS/I9001OXXKP5 Versión del HW: MP 0.500none Bluetoth MAC: 84:25B:F6:8F:41 IMEI antiguo: Desconocido IMEI nuevo: 357160-04-945668-5 Deactivating MSL... And is "Deactivating MSL" for a long time, no response.. I've flashed the first version KPS to try to repair it, but I did not succeed. Any help? Thanks, Eliot |
12-13-2013, 09:30 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Quote:
12-13-2013, 09:56 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Most likely, You have not connected your device correctly. You need to connect the device to Diagnostic port. Please look in PC Device Manager what COM port is Diagnostic, then select port manually and repeat the operation once again. |
12-13-2013, 18:16 | #8 (permalink) |
Member: 2083655 Status: Offline Thanks Meter: 1 | I have already tried all available ports, and all is the same. He ponders on "Deactivating MSL." It will not be a problem in the software version? Recognizes the smarpthone both USB and UART when I change the recognition in *#9090#.. thanks, sorry for my english |
12-13-2013, 19:00 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please try to re-flash the phone with firmware "I9001XXKQO_I9001ORSMP3_ORS_Slovakia_Android_2.3.6 " from the Support Area, then carefully perform all the steps to connect the device: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. You need to connect the device to Diagnostic port. Please look in PC Device Manager what COM port is Diagnostic, then select port manually and repeat the operation once again. |
12-14-2013, 09:33 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please contact us to Yahoo! Messenger or Sonork, we will look remotely via Team Viewer what You do incorrectly and we will try to help You. Our contacts You can find in our profile. |
