Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2007
Member: 621334 Status: Offline Thanks: 148
| GT-i9001 UFTER FLASH WITH OCTOPUS DEAD TRY TO FLASH GT-I9001 LOGO ONLY WITH FIRMWARE FROM SUPORT ,, DEAD ![]() ![]() THIS THE RESULT ,,, Welcome to Octopus Box Samsung software version 1.4.1 ----------------------------------------------------------------------------------- To connect GT-I9001 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in Octopus Samsung software. Selected firmware file: [COLOR=*****Brown]I9001XXKP4_OXAKP2.oct[/COLOR] Please put your phone in download mode and connect to PC. To put GT-I9001 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume-" +"Power"+''Home" buttons. Searching for phone. Please wait... Found phone on Firmware write started. Writing partition.bin section... partition.bin section has been written successfully. Writing dbl.mbn section... dbl.mbn section has been written successfully. Writing osbl.mbn section... osbl.mbn section has been written successfully. Writing amss.mbn section... amss.mbn section has been written successfully. Writing EMMCBOOT.MBN section... EMMCBOOT.MBN section has been written successfully. Writing adsp.mbn section... adsp.mbn section has been written successfully. Writing boot.img section... Writing Firmware Failed Writing Firmware Failed PLEASE HELP ,,, THANKS, |
| | #4 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Oct 2009
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks: 3,601
| Quote:
| | #5 (permalink) |
| TRY ANOTHER FILE ,, THIS THE RESULT ,, Welcome to Octopus Box Samsung software version 1.4.1 ----------------------------------------------------------------------------------- To connect GT-I9001 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in Octopus Samsung software. Selected firmware file: I9001XXKG3_I9001XXKG3_I9001PRTKH1.oct Please put your phone in download mode and connect to PC. To put GT-I9001 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume-" +"Power"+''Home" buttons. Searching for phone. Please wait... Found phone on Firmware write started. Writing amss.mbn section... amss.mbn section has been written successfully. Writing adsp.mbn section... adsp.mbn section has been written successfully. Writing boot.img section... Writing Firmware Failed Writing Firmware Failed PLEASE HELP ,, THANKS. |
| | #6 (permalink) |
| Please fully charge phone's battery and try again. If the problem will be the same - check phone's HW. We have tested on our two GT-I9001 and everything work OK. |
| | #7 (permalink) | |
| Quote:
Welcome to Octopus Box Samsung software version 1.4.1 ----------------------------------------------------------------------------------- To connect GT-I9001 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in Octopus Samsung software. Selected firmware file: I9001XXKP4_OXAKP2.oct Please put your phone in download mode and connect to PC. To put GT-I9001 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume-" +"Power"+''Home" buttons. Searching for phone. Please wait... Found phone on Firmware write started. Writing partition.bin section... partition.bin section has been written successfully. Writing dbl.mbn section... dbl.mbn section has been written successfully. Writing osbl.mbn section... osbl.mbn section has been written successfully. Writing amss.mbn section... amss.mbn section has been written successfully. Writing EMMCBOOT.MBN section... EMMCBOOT.MBN section has been written successfully. Writing adsp.mbn section... adsp.mbn section has been written successfully. Writing boot.img section... Writing Firmware Failed Writing Firmware Failed Selected firmware file: SMD_CSC_GT-I9001-CSC-SERKP6_EMMC.oct Please put your phone in download mode and connect to PC. To put GT-I9001 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume-" +"Power"+''Home" buttons. Searching for phone. Please wait... the battery is full charge ,,, need the solution ,,, thanks. | |
| | #8 (permalink) |
| Most likely, there is problem with phone's flash chip. Please try to write firmware using originan Samsung flasher and post the result. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
| 5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 07-07-1999 12:27 |
| Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 06-09-1999 17:04 |
