07-08-2014, 11:18 | #3 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2056468 Status: Offline Thanks Meter: 11 | I riflashato with this firmware: I9003DDKB2_DDKA5_ODDKA6.oct but still no read here is the log: Welcome to Octoplus / Octopus Box Samsung software version 1.6.1 -------------------------------------------------- --------------------------------- To connect GT-I9003 phone you have to perform the Following steps: 1. Disconnect the USB cable from phone. 2. Go to Menu-> Settings-> Applications-> Development. 3. Turn on "USB Debugging" option. 4. Appear When message is press "Yes". 5. Go to dial window. 6. Enter "* # 7284 #" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Press "Read Info" in the software. -------------------------------------------------- --------------------------------- Platform: Samsung Android Selected port: COM58 Selected model: GT-I9003 Phone was not found on the selected port! -------------------------------------------------- --------------------------------- Platform: Samsung Android Selected port: COM58 Selected model: GT-I9003 Phone was not found on the selected port! -------------------------------------------------- --------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9003 Phone was not found on the selected port! -------------------------------------------------- --------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9003 Phone was not found on the selected port! Searching for USB diagnostic port ... Connecting to phone on COM58 -------------------------------------------------- --------------------------------- To connect GT-I9003 phone you have to perform the Following steps: 1. Disconnect the USB cable from phone. 2. Go to Menu-> Settings-> Applications-> Development. 3. Turn on "USB Debugging" option. 4. Appear When message is press "Yes". 5. Go to dial window. 6. Enter "* # 7284 #" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Press "Read Info" in the software. -------------------------------------------------- --------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9003 Phone was not found on the selected port! Searching for USB diagnostic port ... Connecting to phone on COM58 |
07-08-2014, 11:21 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | What is the phone's baseband now? Connect the device as GT-I9000, turn on USB Debugging Mode in the phone, read out phone's info (press "Read info" button at "Android / EFS manager" tab in the Software) and post here Software log with this info. |
07-08-2014, 11:36 | #5 (permalink) |
Member: 2056468 Status: Offline Thanks Meter: 11 | I see where the baseband? here is the log: To connect GT-I9000 phone you have to perform the Following steps: 1. Disconnect the USB cable from phone. 2. Go to Menu-> Settings-> Applications-> Development. 3. Turn on "USB Debugging" option. 4. Appear When message is press "Yes". 5. Go to dial window. 6. Enter "* # 7284 #" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "* # 9090 #" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in the software. -------------------------------------------------- --------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9000 Reading info, please wait ... Warning: Selected model (GT-I9000) Differs from the detected one (GT- I9003)! If you want select (GT-I9003) as (GT-I9000) model, please check "manual select". -------------------------------------------------- --------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9000 Reading info, please wait ... Detected phone model: GT-I9003 Firmware compiled date: Thu February 10 20:19:07 KST 2011 PDA version: I9003DDKB2 CSC version: I9003ODDKA6 SW version: Unknown Phone IMEI: Unknown Android version: 2.2.1 (FROYO) |
07-08-2014, 11:39 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As You can see from your Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform the "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. If after of writing all firmwares which You have, phone's baseband is still Unknown - most likely, this is HW problem (problem with eMMC flash chip). | |
