06-07-2015, 09:32 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 608370 Status: Offline Thanks Meter: 89 | Gt i9500 unable to repair imei ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Searching for a phone. Please wait... Phone found. Firmware compiled date: Thu May 30 00:52:45 KST 2013 PDA version: I9500XXUBMEA CSC version: I9500OJVBMEA SW version: I9500XXUBMEA Phone IMEI: 004999010640000 Phone SN: R21F91XB4ZR Android version: 4.2.2 (JDQ39) ROOTED Root_GT-I9500_4.2.x.oct SuperSU-v1.65.zip Selected firmware file: Root_GT-I9500_4.2.x.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Firmware writing successfully completed. WRITING CERTIFICATE........................ Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Selected file: C:\Documents and Settings\Ahmad Jee\Desktop\i9500 cert \Cert-GT-I9500_357376052766980_RF1D56NMH5.cert Detected phone model: GT-I9500 Firmware compiled date: Thu May 30 00:52:45 KST 2013 PDA version: I9500XXUBMEA CSC version: I9500OJVBMEA SW version: I9500XXUBMEA Phone IMEI: 004999010640000 Phone SN: R21F91XB4ZR Android version: 4.2.2 (JDQ39) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Checking for compatible Certificate and phone... Certificate is compatible Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes BUT RESULT STILL SAME........... |
06-07-2015, 13:49 | #2 (permalink) |
Freak Poster Join Date: Nov 2014 Location: argentina
Member: 2298273 Status: Offline Thanks Meter: 9 | intenta esto: 1- flash the firmware of sammobile , seccion ARO argentina I9500UBUGNG1_xxxxxx_I9500UBUGNG1_HOME and wipes factory, luego root , etc 2- repair efs and chose imei of service of octopus box i have the same problem and and I solved with this |
06-08-2015, 08:14 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Try to do exactly the next: 1. Make Repair EFS. 2. Re-flash the phone. 3. Make Repair IMEI (write service IMEI from the Software list, not any IMEI). 4. Re-flash the phone again. 5. Re-start the phone, search and select network manually. 6. Post here full Software log with all of your actions and say the result. |
09-11-2015, 10:27 | #4 (permalink) |
Insane Poster Join Date: Dec 2014 Location: Belgrade
Member: 2312844 Status: Offline Thanks Meter: 29 | Hi Team, i need help I received a samsung i9500 with a strange IMEI NULL problem. When i flash phone i got some IMEI but no network, after i repiar imei i got mesage IMEI SUCCESSFULY REPAIRED, after that phone imei again NULL... What to do? Tnx BR Welcome to Octoplus/Octopus Box Samsung software version 2.0.4 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Repair EFS was canceled ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Repair EFS was canceled ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 Detected phone model: GT-I9500 Firmware compiled date: Sat Oct 18 18:15:34 KST 2014 PDA version: I9500XXUGNJ1 CSC version: I9500SERGNJ1 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9500-Unknown11-09-2015_11-07-16-.asec file Cheking security type... New security type is detected Executing exploit... Exploit has been executed successfully Old IMEI: Unknown New IMEI: 352993-05-004466-8 Repairing IMEI ... Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. |
09-11-2015, 10:32 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please perform steps described in previous post. |
09-11-2015, 11:53 | #6 (permalink) |
Member: 2312844 Status: Offline Thanks Meter: 29 | TNX imei Solved, but i cant find network, i will check hardver... tnx one more time.... Welcome to Octoplus/Octopus Box Samsung software version 2.0.4 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Repair EFS was canceled ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Repair EFS was canceled ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 Detected phone model: GT-I9500 Firmware compiled date: Sat Oct 18 18:15:34 KST 2014 PDA version: I9500XXUGNJ1 CSC version: I9500SERGNJ1 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9500-Unknown11-09-2015_11-07-16-.asec file Cheking security type... New security type is detected Executing exploit... Exploit has been executed successfully Old IMEI: Unknown New IMEI: 352993-05-004466-8 Repairing IMEI ... Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 Selected file: D:\FLASH FILES\Cert-GT-I9500-357504051787646.cert Detected phone model: GT-I9500 Firmware compiled date: Sat Oct 18 18:15:34 KST 2014 PDA version: I9500XXUGNJ1 CSC version: I9500SERGNJ1 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Checking for compatible Certificate and phone... Certificate is compatible Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Repair EFS was canceled ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Selected firmware file: I9500XXUFNF3_I9500OJVFNF3 _TUR_Turkey_Android_4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing PERSDATA section... PERSDATA section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9500 Firmware compiled date: Fri Jun 13 13:40:02 KST 2014 PDA version: I9500XXUFNF3 CSC version: I9500OJVFNF3 SW version: I9500XXUFNC1 Phone IMEI: 004999010640000 Phone SN: RF1D45EJGGR Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9500-Unknown11-09-2015_12-01-06-.asec file Cheking security type... New security type is detected Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Executing exploit... Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 Detected phone model: GT-I9500 Firmware compiled date: Fri Jun 13 13:40:02 KST 2014 PDA version: I9500XXUFNF3 CSC version: I9500OJVFNF3 SW version: I9500XXUFNC1 Phone IMEI: 004999010640000 Phone SN: RF1D45EJGGR Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 Detected phone model: GT-I9500 Firmware compiled date: Fri Jun 13 13:40:02 KST 2014 PDA version: I9500XXUFNF3 CSC version: I9500OJVFNF3 SW version: I9500XXUFNC1 Phone IMEI: 004999010640000 Phone SN: RF1D45EJGGR Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9500-Unknown11-09-2015_12-10-27-.asec file Cheking security type... New security type is detected Executing exploit... Exploit has been executed successfully Old IMEI: 004999-01-064000-0 New IMEI: 352993-05-004456-9 Repairing IMEI ... Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing PERSDATA section... PERSDATA section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. |
