01-22-2015, 10:52 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | GT-I9515 unlock [Solved] Platform: Samsung Android Selected port: COM72 Selected model: GT-I9515 Reading info, please wait... Detected phone model: GT-I9515 Firmware compiled date: Wed Mar 5 21:20:18 KST 2014 PDA version: I9515XXU1ANC2 CSC version: I9515OJV1AND1 SW version: I9515XXU1ANC2 Phone IMEI: 3553000000000000000 Phone SN: R38F80SF61Y Android version: 4.4.2 (KOT49H) Last edited by Octopus box; 01-23-2015 at 08:26. |
01-22-2015, 12:56 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. You can unlock GT-I9515 phone via "Write Cert" operation: 1. Root the phone. 2. Perform "Wipe Security" operation. 3. Perform "Write Cert" operation. Cert files for I9515 are available in Support Area. |
01-22-2015, 14:42 | #3 (permalink) |
Member: 1418524 Status: Offline Thanks Meter: 186 | Welcome to Octoplus/Octopus Box Samsung software version 1.8.1 ----------------------------------------------------------------------------------- To connect GT-I9515 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: GT-I9515 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM6 Mode: Normal Phone model: GT-I9515 Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Mar 5 2014 Firmware released time: 22:03:35 Phone IMEI: 355301-06-098626-5 SW version: M9615A-CEFWTAZM-4.0.17135 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: GT-I9515 Detected phone model: GT-I9515 Firmware compiled date: Wed Mar 5 21:20:18 KST 2014 PDA version: I9515XXU1ANC2 CSC version: I9515OJV1AND1 SW version: I9515XXU1ANC2 Phone IMEI: 355301060986265 Phone SN: R38F80SF61Y Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Mar 5 2014 Firmware released time: 22:03:35 SW Version: M9615A-CEFWTAZM-4.0.17135 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-GT-I9515-355301060986265-22-01-2015_18-57- 28-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9515-355301060986265-22-01-2015_19-05- 25-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: GT-I9515 Selected file: D:\FlashFile\Octopus\Samsung\Certificates\cert_gt-i9515_ 35216806251905.cert Detected phone model: GT-I9515 Firmware compiled date: Wed Mar 5 21:20:18 KST 2014 PDA version: I9515XXU1ANC2 CSC version: I9515OJV1AND1 SW version: I9515XXU1ANC2 Phone IMEI: Unknown Phone SN: R38F80SF61Y Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... not done |
01-22-2015, 14:54 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Fully charge phone's battery, make Factory data reset and wipe cache partition and try again. Also, look here: http://forum.gsmhosting.com/vbb/f684.../#post10780867, http://forum.gsmhosting.com/vbb/f684.../#post10768572. |
01-23-2015, 06:41 | #5 (permalink) | |
Member: 1418524 Status: Offline Thanks Meter: 186 | Quote:
