05-23-2018, 10:20 | #1 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2126418 Status: Offline Thanks Meter: 8 | GT-N7100 can not upgrade [Answered] I have N7100 for service who stack on logo. I try to flash it but with no luck now after that attempts The phone didnt power on Welcome to Octoplus Box Samsung software version 2.6.9 ----------------------------------------------------------------------------------- To connect SM-J320FN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. MyExceptionEAccessViolationAccess violation at address 00A25FD6 in module 'OctoplusSamsung.exe'. Read of address 00000049 TAdvStringGrid ----------------------------------------------------------------------------------- To connect SM-J320A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect GT-N7100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. Selected firmware file: N7100XXDMB2_OXXDMB1 _EUR_Greece_Android_4.1.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-N7100 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed Performed by 2.6.9 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-N7100 Operation: Read EFS Proper android device not found. Make shure that "USB debug" option on the device is turned on. Reading EFS failed. Performed by 2.6.9 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-N7100 Operation: Write EFS Operation was canceled Writing EFS was canceled. Performed by 2.6.9 Software version. Selected AP file: C:\Users\Petros\Downloads\N7100XXUFNL1 _N7100EURFNL1_EUR\N7100XXUFNL1_N7100EURFNL1 _N7100XXUFNG1_HOME.tar.md5 Please put the phone into Download Mode and connect USB cable. To put GT-N7100 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing TZSW section... TZSW section has been written successfully. Writing SYSTEM section... Writing Firmware Failed Performed by 2.6.9 Software version. Last edited by Octopus box; 05-23-2018 at 12:32. |
05-23-2018, 12:31 | #2 (permalink) | |||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Quote:
08-11-2018, 17:33 | #3 (permalink) |
Junior Member Join Date: Oct 2006
Member: 376115 Status: Offline Thanks Meter: 2 | N7100 unable to know proper version new replace emmc with android 4.1.2 but no baseband occur reflash with different version 4.3 became bootloop and unable to downgrade nor change version. error rpmb:invalid rpmb data so i decide jtag again with copy of new emmc with android 4.1.2 Phone found. INFO : 8/11/2018 9:01:28 PM > Detected phone model: GT-N7100 INFO : 8/11/2018 9:01:28 PM > Firmware compiled date: Fri Jun 28 14:29:14 KST 2013 INFO : 8/11/2018 9:01:28 PM > PDA version: N7100ZSDMF2 INFO : 8/11/2018 9:01:28 PM > CSC version: N7100OZSDMF2 INFO : 8/11/2018 9:01:28 PM > SW version: unknown INFO : 8/11/2018 9:01:29 PM > Android version: 4.1.2 (JZO54K) INFO : 8/11/2018 9:01:29 PM > Sales code: TGY INFO : 8/11/2018 9:01:29 PM > Country: Hong Kong INFO : 8/11/2018 9:01:29 PM > HW platform: exynos4 INFO : 8/11/2018 9:01:29 PM > HW Chip: smdk4x12_prime INFO : 8/11/2018 9:01:29 PM > HW Modem: unknown INFO : 8/11/2018 9:01:29 PM > Codename: t03gzs INFO : 8/11/2018 9:01:29 PM > Performed by 2.7.0.3 Software version. done repair efs. rooted already. it fails to repair imei. what can i do? |
08-11-2018, 17:57 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. As You can see from your Software log, there is a problem with modem part of your device: Quote:
If You have an original EFS/Security backup for this device, write it and check baseband. Also try to read out EFS backup from another GT-N7100 and write it into yourd devcie. If You don't have such backups for this device, You should try re-flash the device with different firmwares one by one and check, whether modem is correct (whether baseband is not "unknown"). And only then, when modem part will be correct, You can try to fix IMEI. | |
