07-21-2014, 08:45 | #1 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2056468 Status: Offline Thanks Meter: 11 | gt-s6500 log: -------------------------------------------------- --------------------------------- To connect GT-S6500 phone you have to perform the Following steps: 1. Disconnect the USB cable from phone. 2. Go to Menu-> Settings-> Applications-> Development. 3. Turn on "USB Debugging" option. 4. Appear When message is press "Yes". 5. Go to dial window. 6. Enter "* # 9090 #" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in the software. -------------------------------------------------- --------------------------------- Platform: Samsung Anycall Selected port: COM87 Selected model: GT-S6500 Mode: Normal Phone model: Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port ... Connecting to phone on COM88 Detected phone model: GT-S6500 HW Version: GT-S6500XKAOMN Phone IMEI: xxxxxxxxxxxxxxxxxx Phone connection failed Connecting to phone on COM87 Mode: Normal Phone model: Phone model is not supported Phone connection failed No diagnostic ports found! Connecting to phone on COM88 Detected phone model: GT-S6500 HW Version: GT-S6500XKAOMN Phone IMEI: 359827-04-068040-0 Detected phone model: GT-S6500 HW Version: GT-S6500XKAOMN Phone IMEI: xxxxxxxxxxx Phone connection failed Connecting to phone on COM74 Phone connection failed |
07-21-2014, 08:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | You have not connected the device correctly. To connect GT-S6500, You have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. Also, try to select correct COM port manually. |
