08-15-2016, 01:51 | #1 (permalink) |
Junior Member Join Date: Nov 2015 Location: Egypt Age: 37
Member: 2484789 Status: Offline Thanks Meter: 5 | gt-s7582 hang on samsung (solved) ----------------------------------------------------------------------------------- To connect GT-I9060I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect GT-S7582 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#7284#" number. 8. Set "UART" radio button to "MODEM" value. 9. Set "USB" radio button to "PDA" value. 10. Press "Save and Reset", phone will restart. 11. Press "Read Info" in software. Selected firmware file: S7582XXUAMK6_S7582OJVAMJ2 _AFR_Kenya_Android_4.2.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-S7582 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing modem section... modem section has been written successfully. Writing DTS section... DTS section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing system section... system section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Firmware writing successfully completed. Performed by 2.3.0 software version Last edited by Octopus box; 08-15-2016 at 10:39. |
The Following 2 Users Say Thank You to Mostafa_dysha For This Useful Post: |
